Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 Just wanted to get some more thoughts on this before I try putting it in. Never done it. Someone said I'd need lash caps. I have an e12 head. I think the motors been rebuilt. I have no idea what kind of pistons. I'm assuming it is a one time rebuild on an otherwise stock motor. Do I need to worry about valves hitting pistons? Do I need to modify oil passages in the cam journals? Stahl header, dual Weber 40's, Ti mech dizzy,Crane ign., Pertronics. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 If you have stock pistons the 301 should be safe. I used one for a race about 10 years ago with no lash caps. No problems. I have been told that the ramps on the 301 are hard on rockers so I only used it once. G Quote Link to comment Share on other sites More sharing options...
