Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 Hi, I changed the front brakes on my dads 95 540i and the brake linings warning light is still on. Is the light on because I didn't replace the brake sensor. Thanks, Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 Could be, but most likely it is a bad wire, usually grounds out somwhere. I would replace it or just remove it all together. If the light is still on after you remove it, the wire is grounded out. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 Yes, you probably need to replace the sensor. They're about $5 or less each. You'll probably find that the area that wears (makes contact with metal and completes the circuit) is still shorted. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
