Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 On my way to Carlisle I was coasting around 75-80 MPH and decided to rev it up a little...Never did 90 so I figure I'd try the car after a year of restoring it. It's got a stock engine to my knowledge with 32/36, stahl header and 318 head. I take it to 90 and then past it. After a minute I look back and see light blue smoke...!@#$% says I. I check out of the nearest exit and I try to see if there's any crack I could eyeball. Nothing but I did notice that the shop filled it with way too much oil, a quarter inch above the upper tick mark... Could too much oil generate enough pressure to push it pass the seal? Or is this a bigger problem like a ring job... I notice that I don't see it till I start going around 90 only so far at 4Krpm... TIA. dM\x. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 URL: http://www.zeebuck.com/02bc/index.htm (nt) Quote Link to comment Share on other sites More sharing options...
