I have my dash and glove box recovered recently. I'm generally happy with quality. But.... Guy mixed up my glove box with someone else's.
I have front glove box pad with 4 bolt holes on the flat surface area. On the other hand, glove box has bolt pattern towards the edge of the box. (photo attached).
I understand that there are several version of glove box. Which one is correct one for my car. I drive 1971 02. (earlier car, 3 piece dash and short console).
My guess front pad is not mine.
Thank you for your help in advance!
I discovered this on my '69--the glove box facing is a different shape from that on my '73...and I can tell you which one is (probably) right for your '71, but won't be able to get to my '69 for at least a week...drop me an e-mail then if you don't have an answer and I'll check it out for you.
It surprised me too--coulnd't believe the logical Germans changed the design for no apparent reason.
cheers
Thanks. Please let me know when you can figure out. No hurry.
You can reach me at tetsmove at aol dot com
regards,
Yep, you got the wrong cover. Here is a pic from my '71. There are four screws on the inside--two along the upper edge and two on the bottom (like the ones in your pic). Hope this helps.
