Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 Its a plastic shell that snap's over the original dash to give it the new look, only complaint is that its a little shinier than I liked Just think of a fresh Armoral job kind of shiny...P.S. Armoral is GARBAGE and it hurts not helps your dash Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 not for 02's. I have a friend who is looking for a dash and this could be a reasonable temporary solution. BTW, I believe that the trade name is Dash Toppers,IIRC. All the best, Harry Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 http://www.dashtopper.com/order/BMW.htm Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 Ayone know if the hard plastic ones are available for 02's? Thanks, HarryPR Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 at this link: http://www.coverlaymfg.com/E_Store/Dash_Covers/Foreign/BMW/ but it doesn't seem to go back to the 'O2s Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 Will post any findings on this board. Regards, HarryPR Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 Dashtops.com has the hard plastic one-piece covers but only for the late models. here: http://www.dashtops.com Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 pretty good fit, if you take the time to follow the directions AND they send you a full tube of the glue. Ive had the glue tube nicked at the bottom so half the glue is no good. You cant just use ANY glue, either... Also the texture doesnt approximate the texture of the '02 dash at all, but as far as looks go they should be OK.. -Rob Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 i'm not gluing anything to my dash! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 20, 2003 Share Posted May 20, 2003 URL: http://www.bmw2002faq.com/02s_online/links.html i suppose you could just stick it up there, but they are designed to be a permanent fix for a cracked/damaged dash. -Rob Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 21, 2003 Share Posted May 21, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
