How to id diff before disasembly?
I'm going to the breakeryard to get a propshaft and
diff for my 1973 2002. Mine are worn and I'd like to
refurbish the ones from the yard and then replace.
How do I id what diff is under the car now, and
what diff is under the many donors at the yard? Or
is there an easily identifyable limited slip diff from
another Bimmer I can use, with the same ratio?
Thanks,
Hugo
The lasd will have an S painted on a side of it and 2 2 digit numbers stamped. devide one by the other and you will get the ration. If the car is in the air, spin one wheel and see if the other spins in the same direction. if it does, you found an LSD.
steve k.
if the junk yard has a few 320's you would be able
to test the amount of slip before removing. Just
has someone hold one wheel while you spin the
other side, the more "torque" to brake the slip the
better, you may not even have to rebuild. If you
don't have a second hand, jamm something on
one wheel. Have fun...
Michael
