No, but the luckily the finger still does.
Way to start my weekend with a good laugh. Thanks.
1974 polaris A 4281992 (total resto with 5-spd conversion)
1976 jadegrun 2744974 (sold then killed by the new owner, grrrr!)
1976 sahara A 2392532 (sold)
1971 nevada 2571108(RIP)
All BMW's I've had only work with the key on acc or above!
Good luck troubleshooting.
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
Key must me on Acc or On.
-Nathan
. . . if the key is not on?
I'm troubleshooting my non-op horn and want to know if I can do so without leaving the ignition in the on position.
Key on for me (never tried acc.)
Someone correct me if I'm wrong - but you can unplug the coil primary side to avoid burning up the coil and points to safely keep the key in the on position during trouble shooting.
1971 BMW 2002
38/38 DGAS
292 cam
TEP 4-1 header
Ansa Sport muffler
Bilstein Sports
H/R Sports
Full Urethane
Bavaria Control Arms/02 Tension Rods
IE adjustable sways
15x7 König Rewind
Should work I don't see why it shouldn't.
E23 730 1978
Now a useful tip-
Unplug the wire going from the relay to the horn(s). Plug in a simple 12v lightbulb instead. This allows you to test the horn circuitry without pissing off your spouse or neighbors.
Should be a simple system to trace- horn button, relay, +12v, horn, grounds. Half-split the circuit. See if you are getting continuity at the relay between the horn switch wire and ground. Then see if the relay closes when you press the horn button.
Steve J
& too many bikes
