Gas Pedal Slipping
Is there a nut or something that holds the gas pedal in the correct position on the arm coming out of the pedal box? My gas pedal seems to slip off to the right, then doesn't go all the way to the floor, making full acceleration impossible. Where can I get the replacement bits to reattach it?
There's a 6-mm bolt with a nut that runs through the arm and clamps it onto the pedal shaft. Access via under the car.
The pedal should fit pretty tight on those two studs. If its cracked then it will wobble around like you described. Might be time for a new pedal.
Matthew Cervi
'73 tii
