In my regional historic racing class 2002s are allowed to have up to 13x7 wheels.
Is anyone aware of any 13x7 wheels with either 205/60 or 185/60 rubber Toyo R888 that fit on a lowered non-flared 02. Fenders will probably need to be rolled.
My build plan specs;
- E21 front vented rotors with 2002 Turbo calipers
- E21 rear drum brakes
- IE adjustable coilover on front - 2" lower?
- IE adjustable caber plates on front
- IE race spring on rear with sport springs - 1-1/2" lower?
- upside-down subframe mounts (still not sure if I have to match the offset on the diff mounts)
What would be the ideal/max offset on a 13x7 wheel?
What would be the ideal/max offset on a 13x6 wheel?
Any thoughts and recommendations on wheel options would be most appreciated.
cheers
  • Alpina
I ran a set of 13x7 205/60 Ronal racing wheels on my rolled/pulled 02 with camber/coilover not sure of the offset. Very light wheels!
Similar to these
http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,362389/
http://www.instagram.com/mojojoy
1968 BMW 2002 (Bristol/Granada)
1969 BMW 2000 NK (Florida)
1971 BMW 2000tii Touring Malaga (Restoring)
springs and ride height, suspension travel,
lots of negative camber, OFFSET all determine how much rub
tug on the front fender arches
roll the rear fender arches with bat
205x13" & Korman coil-over ITB suspension
'64 R27 250cc #383851 18,000m
You may run into trouble with the calipers vs. backspacing in front.
I got the 528 calipers to work with Panasports on a tii strut.
Took a bit of grinding to get that to work,
and I had to shift wheelweights around to get it to fit, it was that tight.
Previously, I'd had e21 calipers with a lot of clearancing done to them.
In back, it shouldn't be a problem.
You'll want an et in the high 20's on whatever wheel you find-
and they're hard to find.
205's ought to work, in 60 series.
I think you can get it to work OK, it's just going to be cozy.
c.d.iesel,
Your car looks great! What 13" wheels are on your car? Are they 6 or 7" wide?
Tug on fender arches – you mean actually pull them out by hand? - how much did you need to pull out? Nice solution, I have never heard of this.
Please post or email me more pics.
thx so much for your input
