Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 Lesson # 324 grasshopper: do not fiddle around with working systems the day before an 02 event... i should have paid attention that day in class: yesterday we decided to put an end to the flickering alt. light and the weird readings on my voltmeter by replacing the stock 45 amp 2002tii alt. with a Bosch 41x, out of a 528, 633, etc. The 41x has internal vlotage reg-good, and is 65 amps-great. So, after fabbing up a longer tube for the tii specific bolt and after waiting all day to do other things, we get around to install at 7:00p.m.. remove rad., etc... get new alt. in... and crap: it reads under 12 volts- bad alternator. we tried new v. reg on it, checked everything again.Nada- bad alternator.That is what i get for putting an unknown piece in the car. SO, then we get to take it out, and put the original back in with some improved wire harness ends( the original plug is gone). Now, the damn thing is reading a steady just over 12 volts, i have shop grunge all around the place that i spent hours cleaning, and i get to go through the whole stupid routine again, when i get a correct reman 41x from supplier. got home 11.00 p.m., almost forgot my grills at the shop, lost some stuff, what a mess: all on show's eve. But, at least i got my horn to work on my new Momo Alpina wheel: found the last 2 plunger horn contacts in the universe lol, at "scary Ed's". He is great! See you at Palo Alto, a bit weary and a lot wiser.../// Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 working late last night to get the car running. But the oil cooler is now in and working. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 .....over PLUG WIRES!!! It was running well enough weds. but NOOOOO. I head to mess with it. I'm pretty sure it was never the Pertronix OR the timing that was giving me headaches. Just a coincidentall intervention by some severely corroded-very green, plug wires and cap. I was able to clean the cap but the wires are green right past the connectors and into the wire-bad conductor that green stuff. Semi-conductor anyway. The coil wire actually disintigrated in my hands. Well, the fix is usually easy but the parts acquisition tough. Hopefully I'll find some wires to limp me along to Road America. Glad you made it through your ordeal the wiser. I'll probably never learn. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 tii or blue new mini, I'll be looking for the 02 bunch, Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 So, I hop in the 02 this morning at about 8:30. She starts right up and I proceed to back out of the driveway, but my clutch pedal is squeaky and binding on itself and I try to ignore it. The next moment the clutch is slipping because the pedal is jammed, so I pull the pedal up with my foot... too fast! The clutch engaged, torqued the engine, and slammed the dizzy into the fire wall causing the cap to impact the rotor. The cap has a huge hole in it and the rotor is cracked in half!!!! I live 45 minutes from the closest parts store that might have a cap and rotor for my poor little 02!!! I just drove the M5 into San Rafael and picked up a rotor, I couldn't find a cap. This trip took 1.5 hours. It's 11:am now and I'm leaving my house in the 02. I replaced the rotor, epoxied the cap, and fixed the clutch pedal. I should be in Palo Alto by 1:pm... I hope everyone is still there. Ethan Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 tuning... Mmmm side drafts are fun to tune. Still sub-optimal, but she'll make it. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 then the distributor cap went. What a day!!!! I'm bummed. Ethan Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 18, 2003 Share Posted May 18, 2003 motor mounts?? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 18, 2003 Share Posted May 18, 2003 Got free Giants tickets Friday and didn't have to risk the '02 by fiddling with it. It ran great the whole way, going on one month now. Great show. I tip my hat to JP and Arne and all the others who put this on, well organized event. It's my first one, but I'll keep going to 'em. Great to see people's faces finally, too. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 18, 2003 Share Posted May 18, 2003 control arms!!! I requested a flat bed tow truck and got one, but the driver hooked on to the control arms with his hydraulic hooks, bent the arms to shit and dinged up the front sub frame. What a day. I hope tomorrow brings me better luck and if I go anywhere I'm driving my truck! Judging by the pix so far it looks like I missed a really good time. I was really looking forward to seeing some nice cars and meetig some of you. Regards, Ethan Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 19, 2003 Share Posted May 19, 2003 contact the tow truck company. they are responcible for the dammage. steve k. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 19, 2003 Share Posted May 19, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
