Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 I just installed an older Cannon intake, set up for a Weber Downdraft. It runs terrible at low RPM, and I can't seem to find any vacuum leaks, all the nuts are tight, and the gaskets are new. When I spray ether near the intake runners, RPMs increase. Any body seen this before, and have any ideas for a fix ? Thanks! Jerry Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 Hi, that sounds like a problem that plagued me once many years ago. i put a two barrel set up including the manifold onto a head and the motor ran like crap. in the end the problem was that on one of the intake runners of the manifold it had a gasket frozen to it and on the corresponding head port i had put a new gasket. it sounds goofy and was very hard to see but the manifold just wouldn't tighen down with the gasket doubled-up.also check all of the 6mmbolt holes in the manifold because sometimes they are drilled through to the runner inside. good luck stone Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 Hi. Thanks for the help. Where are the 6mm bolts located that you referred to ? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2003 Share Posted May 17, 2003 the bolt holes are on top of the maniflod where the original emissions equip was mounted. Quote Link to comment Share on other sites More sharing options...
