Guest Anonymous Posted May 16, 2003 Share Posted May 16, 2003 my spark plug wires? I've heard of people talking about them but my car didnt come with the exhaust manifold so I'm not sure if it's something every car should have or not??? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 16, 2003 Share Posted May 16, 2003 ...since the wires would likely get pretty toasted otherwise. If you haven't put the manifold on yet, a gasket with an integral heat shield was used on E30 318s ('84-85) that is supposed to work pretty well. The stock 2002 piece was a cast-aluminum affair that went over the manifold; you should be able to get one used pretty cheap from someone on the board. -Dave Colorado '71 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 16, 2003 Share Posted May 16, 2003 Plus it hides the rust ugly ole manifold until i can be arsed to paint it silver P/N 11621723876 or so my receipt says.... I threw the original BMW spec rusty old heat shield as far as i could, so long as your plug wires are too droopy, they shouldnt get hot enough to cause concern. Mine didnt for the few months or so... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 18, 2003 Share Posted May 18, 2003 The late 318is has a completely different engine (M42) dual cam 16 valve high compression and headers. Quote Link to comment Share on other sites More sharing options...
