Guest Anonymous Posted May 16, 2003 Share Posted May 16, 2003 I was just looking at the turbo calculator on http://www.bsmotor.com/ and I was wondering how many psi 1.0 bar of boost is. I was thinking that it would be 14.7psi But I don't know. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 16, 2003 Share Posted May 16, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 16, 2003 Share Posted May 16, 2003 The pressure of a system is defined as the force exerted by the system on unit area of its boundaries. This is the definition of the absolute pressure. Often in measurements a gauge is used to record the pressure difference between the system and the atmospheric pressure. This is called gauge pressure and can be stated by the following equation: P=Pg+Po P=absolute pressure, Pg=gauge pressure, Po=atmospheric pressure. If the pressure of a system is below atmospheric, it is called vacuum pressure.The SI unit of pressure is pascal (Pa): 1 Pa=1 N/m "bar" is used in many industrial applications: 1 bar=0.1 MPa This unit is approximately equal to atmospheric pressure: Standard atmospheric pressure=1.01325 bar= 101325 Pa In hydraulic "m of water" is common: 1 m of water=9806.65 Pa Many gauges use Mercury (Hg) as the measurement medium. 1 mmHg=133.4 Pa Other units are: dyn/cm=0.1 Pa kgf/cm=kp/cm=at=98067 Pa lbf/ft=47.879 Pa in (H2O)=249.08 Pa in (Hg)=3386.4 Pa psi=lbf/in=6894.7 Pa ksi=1000 psi=68.947 MPa 14.7/1.01325 = 14.507772 Cheers! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 16, 2003 Share Posted May 16, 2003 from: http://www.taftan.com/thermodynamics/PRESSURE.HTM John N Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 16, 2003 Share Posted May 16, 2003 John, you put us all to shame by working it out. Quote Link to comment Share on other sites More sharing options...
