Guest Anonymous Posted May 15, 2003 Share Posted May 15, 2003 I have a 76 02 and the Green light "B" on the dash (clusters) in "ON" when ignition is turn on. What is this mean? Thanks Rae Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 15, 2003 Share Posted May 15, 2003 still work, and you can live with the light, don't worry. Check the FAQ for replacement options. Cheers! John N Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 15, 2003 Share Posted May 15, 2003 under the dash (just above the hood release lever), carefully pry off the plastic cover and I'll bet you'll find one set of points inside the box are stuck closed. If they've not welded themselves together, pry them apart, clean the point surfaces with a little fine sandpaper and try the turn signals while you watch the points. The big set makes the outside lights blink, the small set does the inside blinker light. If the electromagnet that makes the points move is dead, you'll have to replace the flasher unit. Cheers Mike Quote Link to comment Share on other sites More sharing options...
