Guest Anonymous Posted May 14, 2003 Share Posted May 14, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2003 Share Posted May 14, 2003 group purchase, I need stuff too! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2003 Share Posted May 14, 2003 be more easily available at least in Portland, OR they are. Try your local VW import parts place. Who knows GEMI might even make the ones that Wurth sells. They are the euro style hose clamp. -Jaycen 72 tundra tii 72 agave 2002 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2003 Share Posted May 14, 2003 the clamps wurth sells, unless our shop is getting the bad wurth stuff (which there really isnt much of) are total crap. you really cant put much torque on them betofe they strip. unless you are doing a really proper restoration you are really better off with the style that has actual slots!! -ian Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2003 Share Posted May 14, 2003 URL: http://home.earthlink.net/~nharren/index.html (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2003 Share Posted May 14, 2003 it is not as wide so not as much torque is needed to achieve the right lbs/sq in. If you strip a wurth clamp before the hose stops seeping, there is a corrosion problem or something else that needs to be fixed. Quote Link to comment Share on other sites More sharing options...
