Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 For those of you that are running sidedrafts, how have you adapted the coolant connection on the back of the water pump to bypass the intake manifold. Tii coolant tubes are quite expensive. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 Thanks Home Depot Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 an E30 with a 4-banger. Cheers! John N Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 A straight tube or the one from an E21 will work just fine. On the tii, it is usually the firewall end that corrodes and breaks off. The 320i part is the same at that end. If I was handy with a torch, I would like to disassemble a 320i pipe to repair a bad tii pipe. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2003 Share Posted May 14, 2003 I'd be driving a Tii Quote Link to comment Share on other sites More sharing options...
