Head gasket
tbrduc
Hello,
I'm going to do it..new head gasket. It just overheats too much and prior evidence indicates a need. (water in oil)
I've ordered the kit from Blunttech.
I have 2 manuals and the tools, space and mechanical ability.
I don't have experience on THIS particular task though.
I'll be chatting with ClayW later today, but, besides securing the timing chain and gear, what other 'gotchas' should I be aware of?
The exhaust manifold bolts are all loose!!
I'm going to do this on Saturday and hope to complete it.
I live in Vienna, VA, if someone wants to come by and offer support, assistance or whatever.
I will have Smithwicks and Guinness on hand for afterwards.
Thanks.
..tom
Sorry but I'm busy Saturday also. Just fininshed my rebuild on a spare engine, which I haven't installed yet. Also have a good spare rebuilt E12 head you can look at for comparison. I have a torque angle guage if you need it.
Post some pics of the head so we can take a look at it too!
Look for cracks between cylinders and specially between water and oil passages since you have had the problem of oil and water mixing.
Also check for advanced corrosion on it.
Besides making sure the timing doesn't move just make sure you torque to the right specs and that everything is super clean. Now that you are opening the engine it would be a nice time to clean the piston heads with some solvent, adjust valves and change the oil (if you cleaned with solvent it gets thinner and contaminated).
To check for warps you can also use a glass big pane of glass and a very good light.
Best advice I can give is make sure the area where you are placing the new gasket is VERY clean use some very fine grit sand paper but not as fine as to polish it.
That's all the advice I can think now!
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
once you have the head off I suggest you not only check it for warpage but that you take it to a machine shop capable of PRESSURE testing it for cracks and warpageand repairing said problems. Blown head gasket/overheating usually is a SYMPTOM of the above problems and/or shot water pump or radiator full of crud or cooling passages in head/and block full of crud OR ALL OF THE ABOVE...Just changing head gasket quite possibly will not do more than ameliorate One symptom. (Zen And The Art Of Motorcycle Maintenance.R. Pirsig auth..loosely quoted).. Good luck [/u]
CarlkkinMadCity
'74 ex-malaga 8 yr. driving restoration
4-spd, recaros, front bbk, I.E. bars+.s.exhaust. heater refurb(thanks Kieth), total motor rebuild 175 mi ago
(thanks Steve P., Jeff I.)
I 2nd what Carl said,
you aint going to do this in a day
line up a local machine shop for resurfacing and pressure testing
the head, with the front timing cover attached
cooling system repair:
recore radiator, new water pump and thermostat, hoses and clamps
through cleaning of the cyl. block and head bolt holes
to their bottoms, CLEAN AND DRY!
PLUS the related repairs while the head is off and other
areas exposed:
motor mounts, hoses, wiring, exhaust, idler arm bearings,
heater valve and hoses...................
'64 R27 250cc #383851 18,000m
Are those orange parts corrosion? Need to clean that up real good so we can see. Have a good one!
E23 730 1978
areas exposed:
How many hours if all of the above needs addressed?
1995 Toyota Landcruiser
1975 2002A
1989 Dodge Raider (sold)
1974 Toyota Landcruiser (very sadly sold)
1994 BMW 530i (sold)
1992 BMW 325i (sold)
1970 2002 auto sunroof (sold)
