Guest Anonymous Posted May 12, 2003 Share Posted May 12, 2003 what should i look at? iv been playing with the idle and mixture also the timing. im alone so i have noone here to help. any basic tips? Im kinda lost, I havent done this for over a year. Thanks Andy Rattley P.S. that weber redline page everyone posts, Ive been trying that and it is working to some extent Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 12, 2003 Share Posted May 12, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 URL: http://home.earthlink.net/~nharren/index.html fully warmed up before looking for a hesitation. The choke can stick and cause major hesitation! That said, it sounds like there is a need to clean the carb, it may have clogged passages through the transitional ports (like Carl said). All in all, sounds like a good cleaning and rebuild is in order. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 what does that mean? I'm new with carbs Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 I think the cleaning would help. Ill clean it and post what I find out. Thanks Andy Rattley Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 URL: http://home.earthlink.net/~nharren/index.html Check the float level too. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 If it's inop or incorrectly plumbed it can cause a nasty hesitation. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 ...when does the hesitation occur (e.g., what RPM, light throttle, full throttle, etc)? Chris B. '73 ex-Malaga Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 Fine. So it only hessitates if I go heavy on the throttle. Thanks Andy Rattley Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 Sounds like idle circuits too lean... will cause hesitation, stumbling in transition stage. Chris B. '73 ex-Malaga Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 you're getting a squirt from it when you work the accelerator linkage? No squirt=bad pump/linkage/blockage in the internal piping...lack of accelerator pump action will cause a hesitation when suddenly accelerating. Mike Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 I'm having the same problem with it wanting to die when I step on it. I screwed the idle mixture screw in almost all the way and it got better, but still has some problem. Gotta clean mine out though. Lars Quote Link to comment Share on other sites More sharing options...
