Sills Rockers full or cover
I understand that a cover sills or rockers(as you call them accross the pond!!)
is literally a cover panel.
Is a full sill complete with the cover sill attached or are they 2 seperate items?
Thanks
There are 2 parts in the BMW system-
1 is a stainless steel piece that attaches to the body of the car,
and it's purely cosmetic trim. It often falls off out of ennui.
The other is a steel stamping that's welded to its inner mate to form a tubular
structure that takes most of the force from the front fender structure
(sorry, subframe connector guys, this is the real load- bearing member in a 2002)
Looks like RealOEM calls it a 'covering', and shows the original as NLA.
That actually makes sense, as the original stamping is different than what
you need to repair a shell, as the rear quarterpanel overlaps the rocker's
outer skin, and replaces PART of its load- bearing capacity.
So the 'covering' is the repair part. You'd be hard- pressed to refit the
original rocker panel... unless you were changing most of the rear quarter
metal.
All that said, about 15 years ago when I ordered the sheet metal for Jenn's
car from BMWSeattle, they first got the trim part when they thought they
were getting sheet metal. 'Oops- well, there's one other number here, guess
that's what you want, then- 20% off OK for our screw- up?'
(I miss Vance)
So yes, 'covering', it looks like.
fwiw, www.penskeparts.com sometimes has better picx or descriptions.
Not this time, tho.
hth
I'm right now going through rocker panel replacement. The two article's I found most useful are:
http://www.2002tii-restoration.org/projects/pass_rocker.htm
http://classicmotorsports.net/project-cars/1972-26-2002tii/bmw-2002-rocker-panel-replacement/
I ordered the Rocker panels from Blunt and The rear partial quarter panel from Walloth and Nesch. The panel's from gemany arrived 2 days after I ordered.. I'll be getting rockers sooon.
I am going to mimic the convertible bracing shown from the macartney book.
1968 BMW 1600 US VIN 1560713
manufactured on October 2nd, 1967
http://mybmw1600-2.blogspot.com/
