Guest Anonymous Posted May 12, 2003 Share Posted May 12, 2003 Pictures would be fabulous. Thanks 02MM Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 12, 2003 Share Posted May 12, 2003 I believe the differences are spindle size (tii is larger) and brake caliper mount ears (again, tii is larger) Someone else will have to provide photos. Good Luck, Mike (#87) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 12, 2003 Share Posted May 12, 2003 the only difference that I'm aware of is that the size of the spindle is larger to accomodate the larger brake rotor/hub. I guess the mounts for the rotors would also be different for the same reason. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 13, 2003 Share Posted May 13, 2003 Since the tii brake rotor is larger, the caliper mount would have to be in a different position. Quote Link to comment Share on other sites More sharing options...
