Engine oil leak
doug73cs
I have inherited the classic engine rebuild faux pas from the previous owner. The machine shop neglected to plane both the block and timing cover case at the same time and the engine - which runs very well - weeps oil when hot at the head gasket just behind the timing case/block. There were no details on the rebuild but I assume it is to stock specs.
I know the right thing to do would be pull the whole thing and get it decked as a unit but since the engine is good is there any merit in suing RTF gasket sealant? Any experience with this as a fix?
Doug
If we learn from our mistakes does that mean I have to make them all?
73 CS Polaris
76 2002a Sahara
The shop manual calls for a dab of sealer at the junction/bottom corners where the chain cover and the head join up. You may get lucky and find out the this step was not accomplished during the buildup. You will have to remove the front cover completely to seal these corners being very carefull not to damage the part of the headgasket that forms the borttom seal for the cover.
Good luck
Earl
74 02Lux
02 M Roadster
72 Volvo 1800ES
74 02Lux
15 M235i
72 Volvo 1800ES
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- George Orwell
I have the exact same problem but my timing cover was machined with
the head.... I rebuilt the head with the help of a buddy
I t sucks to have a little weep at the timing cover....so minor engine has never run better but thought of pulling the cover and resealing it makes me wanna groan at the thought of still having it drip
but the engine and bay are so clean so I would rather not have the drip
Some people have told me that they have done complete rebuild and never totally got rid of a drip.....has anyone had a weep/drip for years??
70' 1600 Malaga
75' 2002 polaris 91-95
2000 328i 95k
2003 GMC Envoy-stolen and replaced
2010 GMC ACADIA
1996 Dodge Ram 1500 247k
RTV (oil safe) is your friend.
I've had fine luck with it. you should use it. You'll PROBABLY stop the leak.
Here's the deal- the head gasket compresses under the head differently
than under the front cover. So even if they're machined the same height,
usually the cover sticks up a bit.
If you're really bothered, use a depth gauge, measure how high it is,
then take it to a competent machinist and have them cut that much off.
I'd use RTV. In fact, I do!
Good luck,
Thanks to all. RTV first with all the remedial work I can do and hope for the best. The engine is shiny and bright except for the oil slick running down from the leak. Grrrr.
Doug
73 CS Polaris
76 2002a Sahara
