graphite grease availability or replacement
Henryn02
BMW calls for graphite grease to coat the rear wheel bearing seal lip. It coats the rubber of the seal against the back of the hub. I am having difficulty finding it. Does anyone know where to buy graphite grease? I only need a small amount. It used to be sold in tubes. Or what is a suitable replacement?
..use the same hi-temp disk brake wheel bearing
(moly) grease that's inside the hub bearings
this will work
or this goo
'64 R27 250cc #383851 18,000m
