Guest Anonymous Posted May 11, 2003 Share Posted May 11, 2003 was combing searching the old archives and i read a post by colin that the reason why you have to use volvo 240 front calipers is because the '77 320i vented calipers are single brake line two piston calipers? anyway i have a 77 1502 and they are single brake line two piston calipers too, so in other words i don't have to use a volvo 240 caliper? i need a 80-82 320i hub. is the hub the one that holds the brake rotor or the one that goes on the shock strut? and for the rear a complete 320 rear drum brake set-up. i was thinking of getting this in a bone yard any tips on how to pull the read drums and backing plates? tia, dave Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 11, 2003 Share Posted May 11, 2003 The primary issue with the big brake upgrade is using calipers that will (i) bolt to the strut, and (ii) accomodate a vented, larger rotor. See the FAQ http://www.bmw2002faq.com/brakes/big_brakes.html for more info. The hub is the piece that fits over the spindle, whether you are referring to an 02 or E21 hub. Chris B. '73 ex-Malaga Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 12, 2003 Share Posted May 12, 2003 from a '77 320i (did this conversion on my early, 2 piston caliper '69 using a complete 320i brake system, including rear drums and master cylinder - major improvement in braking power). Installing 320 calipers requires 3 minor modifications for clearance: 1. The rotor "hat" needs to be turned down slightly (about .040" if I remember correctly) 2. The outer perimeter of the rotor needs to be turned down about 1/8" 3. The caliper body needs to have a small amount removed in the area between the caliper and rotor (I used a bench sander) The only other "modification" required was to re-route the hard line that comes off the 320 caliper so it wraps around the '02 strut and fabricate a mount that clamps around the strut to mount the 320 caliper's hard line where the flex hose connects to it. I bought a pair of rotors from Ireland with the machine work already done on them, which avoided having to find a local machine shop to turn the rotors down. Quote Link to comment Share on other sites More sharing options...
