no idle 2002tii
tscoll01
first day out, my 73 2002tii started right up after hour drive started to buck. kept running though, shut car off, turns over will start but not idle even when pedal moved. Can hear fuel pump, tension spring in place? suggestions? sort of reminds me of bad fuel pump but they usually start and run. Mine starts but will not run. Thank you
TRY:
FILLING THE GAS TANK
REMOVING THE MAIN GAS FILTER NEXT TO THE
radiator and blowing it out into a bottle so you
can inspect the quality of gas, and amount of fine
sediment trapped
valve adjustments - really
fuel pressure test - guessing don't count
..."Can hear fuel pump, tension spring in place? "
pump straining ? is that what you mean with "spring"
noise?? = bad pump, clogged filter and strainers,
crushed fuel hose/pipe
'64 R27 250cc #383851 18,000m
