Will an e21 momo hub work on e10?
sorry, I tried the search, and tried to sift through all the answers, but couldn't get exactly what i was looking for. If an e21 steering wheel will fit on an e10 hub, then the same rationale could be applied to the momo hubs and they would be interchangeable, correct?
so now the modification Q: what needs to be modified on the hub? if they were exact fits, momo would have only made one hub instead of making a separate model for the e21, so what's different? i've seen comments about the turn signal cancel as well as the horn contacts, but some of that was mixed in with responses to e30 q's as well. Thanks guys.
1971 BMW 2002 Chamonix
it. The 2002 hub does not since the turn canceling finger is a separate stamped steel part. The E21 hub does not have a horn plunger built into it, it instead has a horn contact ring held in place by three plastic grommets. So you can cut the turn signal canceling finger off of the E21 hub and then remove the contact ring from the E21 hub also. You will then need to install a contact plunger into the E21 hub by using one of the holes that were used to secure the contact ring or drill a new one.
shermanmartinez@hotmail.com
