Fuel hose size for tii?
BradB
I have a '73 tii. For safety reasons I want to replace all the fuel hoses connected to my fuel pump and gas tank. It looks, judging by the O.D. that there may be two sizes.(?)
Can anyone tell me what size hose is used so I can have it in hand when I let the floodgates go?
Thanks!
2012 VW Touareg TDI
2007 Porsche Cayman S
2005 Audi S4
1996 Porsche Carrera 4S
1973 BMW 2002tii
http://www.fototime.com/inv/11E82910DA8C213
Here's the tii fuel hose thread you didn't find while searching. You did search didn't you. :)
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,355479/highlight,/
Cheers and HTH,
Tom Jones
large hose
Original spec hose: 11mm I.D. x 17mm O.D.
Replacement hose from BMW: 12mm I.D. x 18mm O.D.
small hose
8x13mm
'64 R27 250cc #383851 18,000m
Cheers and HTH,
You're right, I didn't. And I did! ;) In fact so much that I was really confused. But I am set now! Thanks a lot!
2012 VW Touareg TDI
2005 Audi S4
1973 BMW 2002tii
large hose
small hose
8x13mm
You will probably need to lube up the 12x18 hose to get it through the body hole...a little Vaseline will go a long way ;)
70 M2 2.5L
large hose
small hose
8x13mm
+1
I cut a V-notch in the 12x18 hose, lubed it up and used a piece of wire to pull it thru the welded tube in the body.
Great ideas!
One thing I can't seem to find is the LENGTH REQUIRED to do the replacement. Guess I'll buy a meter of each and hope for the best. (?)
One meter should be good.
Always buy more than you need of the fuel hoses. I keep extra lengths in my car for long trips. You never know....
While you are in there, replace that 0-ring on the pickup tube at the tank. It is a royal pain to get the twist-in pickup to seat, so only do it once (or like me - do it several times).
