Throttle/Gas Pedal Headache
jrc2002
Rebuilt almost the entire car and gas pedal giving me the most trouble. Had to have pan on drivers side replaced and the 2 balls that the pedal attaches to had bolts welded to them and drilled holes in floor to mount them. Sounds reasonable but the pedal will not stay in place. I have new plastic bushings on linkage. new pedal and slick tape. I have raised the ball mounts up and down with washers, etc. No matter what i do the pedal will not stayin place. Any suggestions? Measurements or photos of where the ball mounts are supposed to be might help.THANKS!
cut the ball mounts off. bolt a cabinet hinge to floor and back of pedal. done.
whomever designed that ball mount system should be tarred and feathered.
or get one of Massive's Gaz pedals. see for sale section for thread.
2xM3
