M20 Triple weber build x2
  • 1 month later...
BMW 2002 Rear subframe removal and installation (performance-street oriented).
I am not responsible for any of your screw-ups. If any of this is confusing, take it to a good shop.
1) Get your car on the lift (for the rear pickup point use the space just forward of the subframe straps [use wood blocks]) and remove the rear wheels. Pull out the new subframe and double check everything is ready to go
2) Remove the exhaust system up to the down pipe.
3) Inspect the existing subframe. I found a couple things that were rather alarming. The diff bolts were attached via regular nuts and were quite loose (so that's what the clunking in the rear during shifts was!)
The other was one of axle nuts was about ready to come off, if not for the cotter pin holding it in place I would have had one nasty reason to call Triple A.
4) Position a tranny jack underneath the diff for good measure.
5) Unbolt both rear axles. WARNING these bolts can be tricky, do not use a common Allan-key but rather a proper Allen-head socket and socket wrench. These bolts are often frozen and can shear off which can be rather frustrating (it's not a bad idea to spray on some wd-40 and let them soak for a while).
Once both axles are removed take the time and check the cv joints. (if a boot is torn consider it bad) Place the palm of your hand on the backside and pivot each joint in a circular rotation, if you feel any grinding or resistance you might want to consider getting another axle or if they're not too bad, new boots and grease (which is a topic for later).
6) Remove the rear drum and unclip the brake shoe retaining clips.
7) Using a flared wrench undo the inner rubber brake line where each side connects to the body line. If you're replacing the rubber lines with stainless steel lines (which is a very good idea) you can always snip the line (watch out for brake fluid) to slide a socket wrench on for that extra little oomph. I snipped my lines, they were so constricted/rotten inside no fluid came out!]
8) Unclip the brake shoes and E-brake cables and pull back out through the backing plate.
Have someone inside the cabin undo the nuts threaded on the other end of the cable and push the threaded ends back out of the retainer rings on the e-brake lever.
Tug on the line from the back to make sure it will come out willingly (might need some cajoling from inside the cabin too, including knocking the retainer pin out of the e-brake lever for more clearance). Rust can build up inside and make it difficult.
9) Now remove the bolts that hold the Differential to the subframe, and loosen the nuts on the driveshaft center bearing support (you don't want to be the drivetrain to be in compression during all this). Remove the rear springs if you haven't already and knock the rear shocks off the bottom stud. Place a second tranny-jack under the rear subframe.
10) Unbolt the subframe mount nuts and remove the subframe mount straps.
Slowly drop the jack while you and a friend simultaneously cajoling the mounts down and off the body studs (rubber hammer helps, but take care not to damage the thread on the studs
11) Now you're free to remove the rear shocks. Undo the jam nuts from inside the trank and push the shock out. Using a rubber hammer remove the rubber upper shock mount (since we're replacing the shocks and they come with new mounts).
12) Now were done removing everything, so go eat lunch or something.
13) First thing is to feed the new e-brake cables up into the cabin, certainly nice to have a friend on this. Pretty straight forward, just the opposite of pulling them out. If you knocked the pin out, from before, just get some nuts on the threaded ends to keep them from going anywhere and leave it for now.
14) Place the preassembeled rear subframe on the jack and bring it up slowly.
Once both side are lined up with pins take the time to attach the rear brakeline since this is when you'll have the most clearance.
Continue to raise the subframe up and slide in the new diff-bolts. On the outside, reinstall the straps and using a new lock nut tighten until snug (NO final torquing yet).
15) Slide the e-brake cables through the holes on the brake shoe backing plates.
16) Next put in your new shocks and springs. The rear shock mounts are very simple. Bilstein provide 2 different type of mounts (a single rubber mount to be pressed in, or two-piece mount, they both function the same way). Using a rubber hammer, hammer them in from the top, it's helps to have your friend pulling underneath.
With the bottom washer and sleeve on the top of the shock slide it up through the rubber mount, add the top washer and nut on top.
Push up the trailing arm and get the Shock onto it's stud and using a new lock nut and washer, tighten it all down.
17) With the shocks and springs in place, next up is installing the brake shoes and drums on the backing plate. Rotate the hex bolt adjusters on the backing plate so that the pin is inward .
Position the brake shoes so that both sides have the pointy end up and attached the bottom retainer spring then place the bottom end of either shoe under the retainer plate on the backing plate.
Now grab the e-brake cable and attached it to the hole in the trailing shoe . Now attached the upper retainer springs and bracket to the upper part of the shoes and put the shoe's pointy ends in either end of the wheel cylinder (this might take a little finagling). Insert the trailing retainer pin (the forward pin should have been installed when assembling the subframe). And slide both retainer clips in place.
With the shoes now secured take the drum and place over top (if it doesn't slide right on DON'T PANIC, simply tap the individual shoes up or down until they line up (at which point the drum will slide on). Last part is to adjust the drums, this simple procedure is covered many places on the internet (and plan on adjusting the drums at every oil change).
18) Now do all of your final bolt tightening. Be sure to tighten subframe mount bolts, Diff bolts & nuts, driveshaft center support bracket nuts, body studs & nuts, trailing arms bolt &nut (it can be tricky to get a wrench over the outside trailing arm nut, bring the wrench in from the front side of the subframe for better clearance).
19) Using a block of wood so as to not damage the trailing arms, compress each arm in turn with one of the jacks (to simulate the car's suspension under load)
and install the sway bar endlink. DO NOT bend the bar to any odd angle, simply disconnect the heim-joint and slider from the endlink bolt, slide them up the bar to your desire spot (the further up the bar you travel the stiffer the bar acts, but go too far and the endlink will bind and break during spirited driving.) then run the bolt and assembly down and thread into the heim-joint. Do not start cinching the heim-joint up the bolt (since the bar should already be at the desired level), simply use the jam nut to make sure everything gets snug.
Now with the sway bars done we're on the home stretch.
20) Next up is the axle installation, using only NEW 10.9 hardware (never reuse these, seen them fail on a number of occasion) and the existing torque plates go ahead and torque everything to spec.
21) bleed brakes (this might take some time and a fair amount of fluid), if you're not familiar with brake bleeding, just use google.
22) reinstall exhaust
23) put rear wheels back on. Lower onto ground and tighten axle nut, this nut is the infamous “jesus nut” and requires *** to properly torque, you'll need a lengthy breaker bar and a heavier guy standing on it to do it justice. Once torqued, take the wheel off and slide a cotter-pin through one of the holes.
24) Done, now go for a drive on a particularly twisty road to enjoy the fruits of your labor!
Andrew - very nice write-up and details. Unless I missed it, is your car going to get the E36 LSD?
If not, then I am wondering why the (old) rear diff hanger bushings were left in place.
Jim
  • 4 weeks later...
Any updates on this build? I love the write-ups!
Couple little updates...
Got myself a period luisi wood wheel from Brad here on the FAQ. Yes I need to shampoo my carpets.
Ended up with this old Becker radio (thanks again Ken!). I love these things, they look great in the 2002. Will be interesting to try and restore it (with Ipod compatibility).
How To Build the Strongest Small-case Limited-slip Differential For Your 2002.
By Andrew Adams of Ireland Engineering ( a n d r e w a d a m s @ I e m o t o r s p o r t . c o m )
Disclaimer: This is not a beginner project, nor is it meant to be a complete diff-bible, and as such, I (or IE) are not responsible for ANY of your screw-ups. There are some topics which are abbreviated.
Forward:
This would not have been possible without the constant teaching from Jeff and Jeremy of IE and knowledge of Rob at Precision Gearing. If this project looks a bit much for you, or you have the money but not the time, call Rob (http://precisiongearing.com/ ).
TABLE OF CONTENTS V6.5----------------------------------
– Basics: How a differential works
– Basics: BMW Differentials
Why the E36 318ti LSD?
Different Differential Cases
Rear Cover Options
– Basics: Performance Options
– Differential Rebuild
- Tech photo w/ part names
- Test break-away
- Removing diff from car
- Side-cover and LSD removal
- Pinion Shaft removal
- Cleaning
- Pumpkin Break-down and reassembly
- Pinion Shaft installation
- Pumpkin insertion
- Side-covers and Setting Lash
Basics: How a differential works.----------------------------
For those who'd like to understand the principles of the differential itself, I've attached some videos that explain it far better than I could (thanks Chevy and Toyota!)
Here's a link describing the basics of a clutch-type limited-slip differential (which is what we'll be messing with).
http://auto.howstuffworks.com/differential4.htm
Basics: BMW Differentials.------------------------------------
BMW uses three different sized differentials. SMALL (168mm ring gear), MEDIUM (188mm ring gear), and LARGE (210mm ring gear).
For the sake of this write-up we'll be focusing on the small case limited slip differentials. These are found (as standard or option) on 4-cylinder BMW's in the 2002, E21, E30, and E36 cars.
Why the E36 318ti LSD?-----------------------------------
The E36 318ti lsd's were the last of the line for smalll case lsd's, and as such were the most capable in handling higher amounts of torque than earlier diffs. This is evidenced in a couple of ways.
– The lsd-cap is .5” thick, the thickest out of any bmw/ZF 168mm diff.
– The output shaft collars are noticeably thicker than the E21 & E30 pieces. It is my understanding that they are the same size as the pieces on the the medium-case differentials, but I have not verified that.
– The ring-gear bolts have a serrated underside for better grip.
These address the most common failure-points on the small case diffs, the cap cracking (or the bearing nose shearing), the splines on the spider-gear shafts shearing, and arguably the most common failure point; the ring gears bolts backing themselves out. With this center section I will have the best chance of having a small-case diff that won't blow up when powered by the 6-cylinder M20. This means there is no need to resort to modifying the rear subframe (or paying someone else an obscene amount of money) to fit a medium case differential.
Differential Cases---------------------------
2002 came with 4-bolt side-covers and bolt-in output flanges (with the ’76s having slightly longer output flanges).
E21 EARLY (08/79 and earlier) – 4-bolt side-covers and circlip-held output flanges
E21 LATE (09/79 and later) – 6-bolt side-covers and snap ring held output flanges
I’ll be using the late E21 open case for this with the beefier 6-bolt side-covers and 10mm cv-joint bolts (in the vain hope it will matter). You “should” be able to use a 4-bolt open 2002/e21 case if the center section coming out of the case is the same width as the Limited-slip pumpkin.
Rear Cover options on the 2002 with small case differential.
2002 EARLY (mid '74 and earlier)
2002 LATE ‘finned’
Alpina Finned*
Alpina Chinese knock-off*
Big Billet Cover*
Tap in AN fittings and run a pump/cooler.*
This differential will be using the 02 late finned cover, all the fancy options would be overkill on a street car. I want this differential to be well-engineered, not over-engineered.
The shorter the gear ratio (higher number [4.10,4.40, etc.]) the quicker the acceleration, but with a reduction of your top speed. There are many differential calculators online that should help you to find your ideal setup.
Basics: Performance Options-----------------------------------------
Rather than go into this in detail, I'll be straight forward. Unless this is a dedicated track/rally/autox car then the extra money spent is largely wasted. The only thing I'll be doing is increasing the brake-away torque, which I will not elaborate on.
If you do have a race-car and could benefit from different ramp-angles, added clutches, polished gears, safety-wire, etc. Then please call a 2002 performance parts supplier you trust (do NOT just use anybody and skimp).
Differential Rebuild-----------------------------------------------
1 Exploded view of the differential case and its components.-------------------------------
2 Remove the differential from car (see Marshall's excellent writeup ----------------------here …. http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,373426/ ).
3 Break away:-------------------------------------------------------
Prior to disassembly, measure the break-away torque of your differential (how much force it takes before the LSD clutches slip). A good percentage of the used E21 LSD's out there today are worn to the point where they hold barely more than a sticky open diff (sorry for those of you who paid $400 for an non-inspected E21 LSD). If you can twist the differential out-put flanges in the opposite direction with your hands then you've got a very worn differential. A healthy stock e21/e30/e36 small case LSD should take between 25-30 ft/lbs before slipping. By measuring now, it will give you a good baseline indication on the condition of the individual components inside the center pumpkin.
I measured my E36 pumpkin to have a break-away of 26ft/lbs, so technically I would be ok if I was to just stick it into the case and call it a day. However, I'm shooting for a bit more than 40ft/lbs. which is about the most I'd want out of a street-oriented LSD. (by comparison SPECE30 medium case LSD’s are limited to 65ft/lbs., and most other 2002 race setups are around 80ft/lbs.)
4 Side-cover and LSD pumpkin removal:-------------------------------
First take off the rear cover and drain the oil, this stuff has a rather distinctive smell. Be sure to do this in a well vented area, or near your mother-in-law.
Pop out the diff flanges, this might take something rather long (big flat-head screw-driver. crow bar, or bar stock.). To prevent damage to the side-cover, use the bolt heads for leverage. With the flanges out, use a standard seal puller to remove the flange seal out of the cover.
Remove the side cover bolts (loosen progressively in a cross-hatch pattern so as not to warp the cover [think head bolts/studs]). With the bolts out gently tap around the side-cover with a thin flat-head screw-driver acting as a wedge; if care is taken you will not leave any lasting marks. As the cover starts to come off you'll see some thin shims, these are important to keep with their respective side as they allow for correct laterally spacing of the center-section inside the case. When you pull the side covers off the center-section will come loose and drop in the case, put some rags underneath to pad the fall or risk chipping the ring gear.
String the side cover and shims together while marking the which side of the case they came off of (I simply used a die punch marking one or two corresponding dots) so when it goes back together everything will be in order.
If you are swapping in a LSD pumpkin, remove it front it's case in the same manner.
4) Pinion Shaft removal:---------------------------------------
Now that the pumpkin and side-covers are removed you're left with the Pinion Shaft and the case itself. To start you'll need to pop-out the old lock ring on the backside of the input flange, you can remove it with a flathead screwdriver or drill.
Now you'll need to loosen the nut and to do that you will need to keep the shaft from spinning. BMW made a special tool that looks like this (if you have one, chances are you don't really need any instruction on how to do any of this). You can easily replicate something to imitate this tool's function. Loosen/remove the nut and tap “in” the shaft from the backside to remove the pinion-shaft. DO NOT take a typical hammer to the backside of the shaft; you will damage it in some way. Use a rubber hammer, and if that proves difficult, use a press.
With the shaft removed you will see that the pinion-shaft has the inner roller bearing pressed on it Toss the crush sleeve on the pinion-shaft shaft into the trash. To remove the inner roller bearing from the shaft you'll need to use the press and a strong bearing splitter. If it proves difficult (like it did for me) then use a torch to heat up the bearing a bit.
Now let’s go back to the case and focus on the inner and outer bearing races left in the case from the shaft we just removed. Start by removing the circular baffle with a couple good punches with the flathead.
Punch out the inner race (preferably with a softer metal rod like aluminum to keep your punch from gouging the insides of the case.)
As the race comes out you will see a spacer behind it DO NOT LOSE THIS, it spaces the pinion gear's depth in relation to the ring gear. Each spacer is specific to that particular ring and pinion.
Punch out the outer bearing race from the inside
You can also use a clawed bearing puller but I found the punch method much easier.
With this done the case is now fully disassembled into its sub-components.
CLEANING -------------------------------------
With the case completely apart clean, everything thoroughly. Thoroughly degrease the inside of the case; you don't want any muck causing havoc on your new bearings. Ideally, bath the case in a solution of degreaser. You can take some emery cloth (or scotch-brite pad) and rub down the pinion shaft along with getting all the teeth of the ring gear and pinion head. Then use brake cleaner (or otherwise) to make sure no residue is left behind. Any spec of grit can damage of your refurbished diff.
Prior to paint I broke out some die punches and stamped the case IE/AA/001 3.64.
Pic shows post paint.
Prep and paint the case in the paint of your choosing (engine enamel, por-15, etc.) likewise, with the rear diff-flange and side-covers.
For giggles I polished the rear cover, do whatever makes you happy (understand that the rear cover helps to dissipate heat so powder coating, painting, or otherwise adding insulation is probably not the best idea in the world.)
REASSEMBLY---------------------------------------
LSD PUMPKIN BREAK-DOWN & REBUILD-----------------------------------
First I compare both the E21 open center-section and the E36 pumpkin, they are the same height, and therefor compatible with one-another.
You'll notice the E36ti pumpkin has a pinwheel on one end, this pinwheel is read by a sensor on the diff case to calculate speed. Since we're not running this sensor, you can remove the speedo wheel (I used a die grinder).
If you are changing the gear ratio, remove the ring-gear from the pumpkin. To do this loosen the bolts a little at a time in a crisscross manner (just like head studs/bolts). With all of the bolts removed you will need to use a punch through the empty bolts holes and tap the ring-gear off (be sure to have some rags down for the ring to land on.
Now we tackle the case, using a bearing puller (or in my case, a bearing splitter and bench press) pull off the roller bearings from either end.
Using the same crisscross method as the ring gear bolts loosen and remove the allan-head bolts attaching top cover to the case. As you loosen the bolts you'll notice the top cover is held in tension by the as the internals expand. (Note the picture still shows the bearing in place, just ignore it)A weak limited-slip (with a low break-away) is simply due to a lack of tension on the internal components i.e. low break-away = worn internal parts = lost material = more space in case = less tension under load.
BLOW UP DIAGRAM OF INTERNAL COMPONENTS--------------------------------------
As you remove the cap you will notice 2 smaller washers (#2 & #3), the top piece is the smaller Diaphragm Spring aka Bellview Washer (make sure you see what way direction this goes in, you don’t want to put it back in upside down). The second washer is the Stop Disk, it has two indents on the bottom that allow for oil flow.
The first large disk is the larger Bellview Washer (#4), this provides much of the tension in the differential. Inspect the top surface near the inside diameter, a worn Washer will have a wear ridge there, if you can feel a change in height with your finger nail, replace the washer.
Next you have the dog-eared Outer Disk (#5), this disk acts like the surface face of a flywheel. It's available in a few thicknesses, with the thickest giving a higher break-away (but go too thick and you'll essentially have a locked diff. with no break-away). Check for any grooves or ridges and replace as necessary. Just as a flywheel you can also “resurface” the side of the plate which faces the clutch plate, just take fine-grade sandpaper (500grit) and scuff the surface evenly. The Outer-Disks on this diff looked and felt smooth, so all I needed to do was a little scuffing.
After the dog-eared Outer Disk you have the Inner Disk aka clutch-disk (#6)(and as you'd imagine it functions in the same way the clutch-disk works on the transmission). These clutch-disks have a grippy high-friction material coating on them. If your disk has no or little material left (will feel smooth to the touch) then it will slip much easier, replace it. These can develop a smooth inner ring and still have a grippy outer-ring, if this is the case, still replace it.
At the center of the LSD we have the Spider Gears and their housings.(#7, #8, & #9) The spider-gear housing pieces are officially known as the Compression Rings (#7) since they are the pieces that moves out-ward under load which put pressure on the clutch disk “locking” the differential. Like the dog-eared outer disk you can lightly scuff the surface. final28.jpg
Just inside and poking out of the Compression Ring, we have the Side Gear (#8) portion of the Spider Gears. The output flanges stick into these so the beefier the better. Check for cracks, if you can, get them magnafluxed along with the other parts of the spider gear and Ring & Pinion.
Finally in the middle are the 4 Bevel Gears and shafts (#9). Check them over carefully for hairline cracks.
From that point on everything on the bottom half of the case is a mirror image of the top, inspect everything and replace as necessary. Once the guts are all ready, use 2 new allan-head bolts [8x16 10.9] to secure the diff-top. Using a press, install the new roller bearings on either end. Make sure to only put pressure on the bearing's inner sleeve. Ignore that all the allan heads are in place in the pictures.
The last thing to do on the pumpkin is to bolt the ring-gear in place. First make absolutely sure there is nothing on either the ring-gear or differential mating surfaces (clean with denatured alcohol or similar). The ring is a snug fit so you might need to warm it up a bit with a torch before sliding into place (Hopefully you’ve waited for the denatured alcohol to evaporate, otherwise torch and alcohol equal BOOM!). Use some longer 12x1.5mn bolts to thread into the ring gear to act as guides as it’s lowered in place. With new bolts (or safety wired original bolts) torque the ring gear bolts down to 110ft/lbs using the slow crisscross method. When they are torqued down apply a dab of paint-pen paint to each bolt edge, this will allow for visual check when you want to make sure the bolts aren’t backing out. (If the paint seal is broke then the bolt has moved.)
Bolt down the top-cap with a couple of the allan-heads (not final torque), and check the break-away torque now while it is easy. I measured mine out to 43ft/lbs before slipping; perfect!
PINION GEAR INSTALL---------------------------------------------
Tackle the pinion gear assembly first, and the first step is to install the new inner and outer races. These can be rather tight, so it's a good idea to have them sit in the freezer a few hours prior to inserting them. On the inner race be sure to set the spacer/washer from the disassembly in prior to tapping the race in. Start tapping the race in until it sits snug on the washer/spacer (tap in the crisscross method to keep the race from going in sideways).
Use a press to install the new inner roller bearing onto the pinion shaft.
Slide the pinion from the inside, then from the other side slide on a new crush sleeve, roller bearing, seal, rear output flange, and the nut. Get the nut started by hand, but then attach the BMW special tool (or your equivalent) to the rear output flange and keep tightening with the socket (though you might need to switch to a breaker bar). At this point it's extremely helpful to have a couple of friends on deck to keep the diff from flopping over.
The factory manual calls for 25ft/lbs. of rotating torque. As you tighten the Pinion Shaft Nut down you'll feel quite a bit of resistance from the crush sleeve, be sure to stop frequently to rotate the flange/pinion by hand. With every twist the pinion should spin easier. Repeat this process until you hit the 25ft/lb mark continually (that is to say the pinion doesn't loosen as you twist) the final feel is similar to putting a finger in molasses (thick but smooth). With the nut torqued down, tap in your new lock-plate (it will be tight but it will expand into the relief slot on the flange [if you don't bend it in half]).
SIDE-COVERS & PUMPKIN INSERTION --------------------------------------
One of the more difficult parts of the entire process is the removal of the side-cover bearing races. Typically a race will have some sort of lip to use a punch or puller on allowing for removal, for some reason the E21 open diff's side-covers have no such access.
The only way to remove them is to carefully drill a few small angled access holes on the face of the cover so you can run a punch through and pop out the race.
(Then mask one end of the hole and fill with some JB weld). If there's a better way, I'm all ears.
Put the side-cover bearing races in the freezer for a half an hour (shrinking them slightly just as before with the pinion).
With the JB weld now dry and the cover's race surfaces clean and flush, take the new race out of the freezer and using your old race as a driver, tap the race in as before. With both side-covers races in, remove each of the old rubber O-rings and replace them with new ones. Press in new out-put flange seals.
With your side covers (and their respective shims) ready it's now time to address how to get the E36ti assembly in without any modification. If you try and take the pumpkin and simply slide it in you'll see that it will not fit.
Remove the 2 Allan-head bolts you bolted in to secure the pumpkin top-cover. Take care that you don't spill the pumpkin guts. With the top-cover removed there is now plenty of room the slide the pumpkin inside the case.
With the case inside, slide in the top cover and simply start bolting the Pumpkin top-cover through the side-cover opening. Use new bolts and some loc-tite,
torque the bolts to 25 ft/lbs using the crisscross method, to get that much torque you'll need to slide the passenger side flange in through the case and mount it stationary (bench vice), this will allow you to tighten a bold, back back the flange off, and rotate the pumpkin until all of the bolts are torqued.
Now with the pumpkin ready, slide one side-cover/shim on (use a little assembly grease) and tighten down 2 bolts. Tip the diff onto the side that has the side-cover bolted in and maneuver the pumpkin so one end sits in the side-cover race, this will line up the diff so you can slide in the other side-cover from the top, tighten 2 bolts as before. Now you're ready to start testing for lash.
Setting Lash----------------------------------------------------------
Please note that the factory manual goes over setting correct lash in-depth using precise measurements. After doing a few diffs via the manual you can start to feel the differences by hand. This is very hard to convey via a technical write-up, but I’ve given it a shot.
Lash defines the contact between the ring-gear and the pinion-gear. Too tight and the friction between the gears will be enough that the teeth will start flaking metal and stress-cracks will soon brake the gears. A too-tight lash can be identified by having a contact patch on the inner portion of the ring gear teeth (and there will be NO give when turning the input flange). Too loose and the gear teeth will shear clean off during high bursts of torque (i.e. drag racing, donuts, burnouts, etc.). This is identified by having a contact patch on the outside edge of the ring gear teeth. A proper lash will have a full contact patch on the middle of the teeth and a little give before the gears mesh which can be felt when turning the input flange.
To adjust the distance between the gears (thus adjusting lash) we use the side-cover shims
These shims compensate for manufacturing tolerances of the pumpkin and can move it laterally within the case. A thicker shim on the driver's side will set the ring-gear further away from the pinion-gear. A thicker shim on the passenger side pushes the ring-gear closer to the pinion-gear. I used Dicum layout fluid to observe the gear contact patch, you can use any sort of marking paste or fluid.
Many shim sizes are still available through BMW and typically cost $8-$10 each.
With all that in mind, the total shim thickness for the two shims on my e21 case was.120”
I test fit the new pumpkin with each shim as it was originally. This proved to be way too tight, there was no give in the input flange when turning and a test swatch of Dicum on the teeth showed a contact pattern on the far inside. For the next test I stacked both shims on the driver's side (pulling the ring-gear away from the pinion gear), that resulted in too much lash (about 1/4” inch before the gears contacted one-another) but it was better than the first test. My ideal lash was somewhere in between, going onto ETK and converting metric to standard I ordered the thickest shim available (.08”) and a corresponding (.04”) shim to maintain the .120” total thickness.
Once the new shims came in I put them on and broke out the Dicum once again.
In the initial twisting of the input flange, I found there was about 1/16th” lash before gear contact (near perfect!). Rotating the ring-gear through yielded a nice fat contact patch in the middle of the ring-gear.
Lash set, and ready to go.
For the final assembly of the side-covers I pulled the 2 test bolts from either cover, added a touch of loc-tite, and torqued down all 6 bolts for each side. As the Piece de resistance I popped on the polished re-drilled output flanges. I'll be using the stock '02 8mm cv-joints for now but will switch the the 10mm E21 cv-joints once the M20 goes in.
Lastly was the rear cover gasket and rear cover. With those in place I had a complete, tough, limited-slip diff ready to be installed and broken in.
That's all for right now, I will be editing all this over the next couple days.
  • 1 month later...
  • 1 month later...
Pretty stoked! Since Weber production switched from Italy to Spain, slip-fit velocity stacks for the sidedraft DCOE40 carb have only been produced in the 1.5" length. I want something longer (either 3-4" straight, or 3" angled [to clear brake booster]).
Playing around....
Alfa inspiration (since they too have clearance issues)....
Getting closer, next its off to the powder coater. (Thinking Alpina red)
These will also be going on the website.
  • 3 weeks later...
Heyoh! Back from the powder-coaters. The powder coat didn't come out perfect on the inside of a few so they'll be priced a little lower than what subsequent batches will be. One more piece down.
Another "workbench update" almost ready to start putting in the stereo. Will have writeup in about 2 weeks.
Hey Marshall, going with Polk front and rear powered by a Rockford 4 channel. Yep, that's an E30 rear brake light.
Kevin, thanks, just wish I could take pictures like you.
Clutch setup is wrapped up.
Lightened 228mm 325i single mass flywheel (ground from 18-19 pounds down to 13.8)
E30 M3 sachs Pressure plate
E30 - sachs organic disk
Close up of the removed material,
I've seen flywheels lightened even more by removing more material closer to the ring gear. NOT a good idea, ring-gear will come off due to the lack of tension holding it in place.
Couple more tidbits.
Found an old cache of Italian Malpassi/FilterKing Adjustable fuel pressure regulators (with inline filter), for those who don't know these were/are used on a lot of old Alfa's and Maserati's. Should be nice for the project.
Some badges, really like the Nebelhorn badge (ski buffs unite!)
