Rear gear for 1600 with 4 speed?
granth
Finally got my 1600 running, it's bit mild/hot street motor JE pistons, knife edge crank, IE valve train,new 1.8 head, 292 cam and 38 carb. It has a 3.64 LSD in it now and seems a bit doggie, not sure I want to go to a 4.10 too much for high use. But will a 3.90 make that much difference from the 3.64? Does the 1600 have that much less torque than the 2.0l to make it feel under power with the 3.64 gear?
TIA
Yup- 3.9's a useful jump, mostly because of the stock trans gear ratios.
If you had a 5 speed, then I'd think the 4.10 would be fine.
It might leave you just a bit short- geared with the 4.
...but that's just my opinion- either would WORK fine.
The 1602's came with 4:11 rear gears. Even with your mods the torque is going to make the car seem slow. If you could find a 4:22 with an overdrive transmission you would bee better off. G
yeah the 4.22/4.27 are hard to find, but it does seem that torque is and issue with the 1600 vs the 2.0l motor's...
The secret is to find a 1991/1992 318 auto E30 cabrio diff.
They're rare, but not much sought after, either.
Then you put those 4.27 gears into an E21 LSD, and viola!
(yes. it's a pain in the butt. and not cheap, by the time you're done)
So you got one of those sitting around, I would love a 4.27 gear set.
I only had to swap out the 3.91 twice today the diff I got off the FAQ a few years ago look good on the bench dry spin test (I did not take a part) howled like a dog! So I put in a welded 3.91 spare from the track car. That really did help the 1600, I have got to think the 4.10 will even be better. I did not have a spare 4.10 until today got to try that next.
