74 hubcentric?
heist
Back with more questions. I was reading other threads and no one has given me a straight answer. One said the late 70's ARE others said all 2002's are NOT. I was looking into small spacers and recently just went BBK front and back. Thanks for the help!
Nope.
2002's do not have hubcentric wheels.
320's DO, so if you have 320 parts for a big brake setup,
you can be.
Nope.
you can be.
I have massive lee's front and irelands rear so I hope not. Thanks for the quick reply
www.tulipcitywheels.com has a very reasonably priced large selection of hubcentric adapters. We just used them for Konig wheels on a 318is. These were plastic. You need the ID and OD. Check the various sizes to see how exact your measurements need to be, .1mm
Ahlem
'76 2002
'90 M3
'90 535i 5 speed
'89 325is '91 318is
'87 325is
Nope.
you can be.
Aren't Lee's front brakes based on 320i hubs and not the stock 2002 ones??? If so, yes your front wheels should be hubcentric. Then they would/should be 57.1mm.
Tom Jones
e21 rear drums are not hubcentric
hee- well, the DRUMS themselves are... that's why they rust themselves on
so well!
And as to the 320 rear hubs... I think they ARE hubcentric to the wheel.
In fact, now that I think about it, I'm sure that they are, because my rear
disc brake conversion is thinner than the stock drum, and I have
to leave a small spacer in there, or the hubcentric Panasport will bind
on the shoulder between the 57.1 mm wheel diameter and the 58mm
(or something in that range) drum centering diameter...
Lily guilded yet?
