Determining if differential is LSD or not.. and gear ratio
I am trying to determine if the diff in a car is LSD. Jacked the rear wheels off the ground and with car in neutral, turned the wheel on one side and the other wheel did not move. Put the car in 1st gear and turned the wheel on one side and the other wheel turned in the opposite direction. Final crude test was got in the car , did a burnout and the car left two equal black tire marks.
The diff does have a finned cover on it. Also is there any easy way to confirm gear ratio other than pulling cover and counting gear teeth? Car is a square light model. Was wondering if the diff had something cool like a 4.11 ratio installed.
Thanks
There should be some stampings on the driver side of the case. You might have to get under the car with a good light and scrape off some crud. But, there will be some numbers and maybe a letter.
For example, if there is "11 S 43" that is a 3.91 LSD. Divide the larger number by the smaller to get the gear ratio. If there is no S, I'm betting it's not an LSD. Also, the LSD would have a white S painted on the passenger side of the case.
The finned differential cover is not necessarily an indicator of an LSD. It's just a late (possibly '76 only if memory serves) standard 02 diff cover. (Of course, it could be an E21 diff cover, but without pictures, I wouldn't know that.)
-David
1972 2002 - 2577652 Follow the fun
You've described an open differential, sorry.
A '76 should have a 3.90:1, others would have a 3.64:1 (I think). There will be numbers stamped on the left side of the housing, 39-10 for a 3.90:1, 40-11 for a 3.64:1. If the internals have been changed then all bets are off.
The numbers can be hard to read, I used a pencil and paper to make a rubbing of mine.
Thanks guys. Car has a lot of grunt off the line and is a late model square light example, so very likely a 3.91
I guess from Muscle car days with posi-traction, I thought the two black marks indicated LSD, "posi-traction", "sure-grip" type diff.
Maybe the dual tire marks are a function of the independent rear suspension.
....and when you remove the diff cover - you will read the ratio
numbers THAT ARE STAMPED ON THE EDGE OF THE LARGER RING GEAR
no mystery - no counting needed
and you will see either a open cluster of gears (open diff)
or you'll see a enclosed 'can' looking center section which
contains the clutch pack of the LS .
'64 R27 250cc #383851 18,000m
The best way to tell is to jack up the rear end. put the car in gear. Grab ahold of one of the rear tires and turn it. If the opposite wheel turns:
same direction - LSD
opposite direction - standard
actually this is not quite true
my dif is definitely lsd and the tires turn in opposite directions
also not all difs have stampings
the only way to know for sure is to take the cover off and have a look
