emissions AHHHHH!
pinkey
I finally took my '02 in for safety and emissions and it failed horribly. I have changed the plugs, cleaned the points and done the timing with a timing light. I also ran a fuel additive through made by CDC that is designed to help with emissions. any other tips or tricks to get it to pass? (I have heard that if you add a bunch of HEET to your gas "which is basically rubbing alcohol" it will pass) but I don't want to hurt my engine. any advice would be great thanks!
Driving a vintage car always makes traveling an adventure.
Make sure it's tuned spot on for the purpose of the test. Also if possible go for a spirited highway drive right prior to the test to make sure it's not in warm up phase...
Tough call tho! Is it running well? Decent gas mileage, not rich at all?
~Jason
1973 2002tii (2764167), Baikal, Rebuild blog here!
--> Blog: Repro tii cold start relay;   + --> Need an Alpina A4 tuning guide? PM me!
is it just an IDLE test ?
or run through a cycle on a DYNO ?
what carb's? tii? got any air pump/EGR stuff still installed?
what did you set the timing to?
jets? float levels?
how old is the motor oil - it will cause bad readings
if gas fouled
where does the cam cover vent go to ?
'64 R27 250cc #383851 18,000m
I am so dadgum glad I live in NC. We stopped the tail pipe "sniffer" emissions testing several years ago. And now I don't have to worry about inspections at all because any vehicle registered in this state that is 35 years old, or older, is exempted from any inspections whatsoever.
The older I get the better I was!
