engine help
wess02
69 2002 32/36 weber
121 ti head
flat top pistons
stock cam
took the car out for a spin yesterday. it was funtastic! ...untill the gas pedal stuck and the engine over revved between 5-6000 rpm's. i shut off the engine as fast as i could but damage had already been done. pulled off to the side of the road. unstuck the pedal. went to start and the engine instantly revved to 3000 rpm, killed it. wait a few minutes while i double checked linkages. then tried again, same thing.
a friend drove past to lend a helping hand. i caught him up on my situation and we went to try again. it idled about 14-1500 rpm and drove it back home 3 blocks away. noticed a knocking sound and lack of power.
compression test right away. and got these numbers
after taking a drive____________before taking a drive
#1----135____________________#1----135
#2----120____________________#2----145
#3----145____________________#3----145
#4----125____________________#4----145
took the valve cover off and checked the rocker arms. noticed a few were WAY out of spec (loose). grabbed my .007 feeler gauge and checked ALL the rockers. that addressed the knocking.
compression test again.
after checking rockers
#1----120
#2----115
#3----120
#4----120
have not checked timing
have not checked for vacuum leaks
started the car today.
notice a rough idle
and a fumey cloud out of the tail pipe.(might be burning oil?)
shut the car off to answer my phone, havent been able to start it again.
when i was out driving. i heard a loud BANG, but cant remember if it happened while the engine revved or after i shut it off. it def. came from the engine.
hoping a few of you could point me in the right direction (C.D, Mike and any others i forget to mention.)
this was a new engine <100 hours on it. built by a reputable shop in the area. and ran BEAUTIFULLY until this happened.
stock used crankshaft (within spec)
first overbore flat top pistons bought new from bav
new rod and main bearings
brand new stock cam bought from bav.
new water pump
new oil pump and chain
new timing chain and guides/tensioner
list goes on.
i feel like shit.
thanks for the help guys.
how she ran before the drive. will post one of how she runs now, soon
If it only went to 6000 I doubt you have any serious problems. Even if it went to 7500 as long as you did not bust a rocker arm I can't believe you did any damage. You need to check everything, the fact that the idle was way up makes me think you have a throttle linkage problem. Look for vacumme leakes and make sure the engine did not move a lot on the mounts (broken?) and maybe hit the dist cap on the coil (seen it done) and crack the cap.
Did you check the compression with the throttle open?
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
Update:
checked the timing. thats still good.
checked for vacuum leaks with starter fluid, sprayed around the base of the carb intake ports on the head, and the deck where the head and the block meet(as best i could) with no affect, on the brake booster and hoses too. nothing.
pulled spark plug wires 1 at a time and the engine would stumble when each was pulled.
incredibly difficult to get a warm start out of it and i have not touched mixture screws on the carb. the engine REALLY moves around in the bay when cranking.
Why is your compression so low on a fresh rebuild? Did you adjust the valves with the engine dead cold (sitting overnight)? Get a hold of a vacuum gauge, that will be better indicator of vacuum leaks as well as timing, carb, or valve train issues.
And just to confirm, was the noise you heard a slow knocking, or fast tapping? I will assume fast tapping because the valve adjustment took care of it. Just for kicks, pull the valve cover again and check for broken springs. You'd have a misfire if that were the case, but it won't hurt to check.
If you can, post up your vacuum reading and what the needle does when it's idling, holding at 3500rpm, and when you snap it open to WOT and back closed quickly. Also give us an oil pressure reading.
1971 BMW 2002
38/38 DGAS
292 cam
TEP 4-1 header
Ansa Sport muffler
Bilstein Sports
H/R Sports
Full Urethane
Bavaria Control Arms/02 Tension Rods
IE adjustable sways
15x7 König Rewind
im going to pull the head, i got a few opinions saying i might have floated/slapped a valve. the valve springs were one of the items NOT replaced. and i heard a loud BANG from the engine before the knocking. wen i get some more time i will dive into it. il be busy for the next day or so.
Jimminy Christmas! Pulling the head because of what you heard?
Do some more looking. I bet there is something simpler.
John
1665778
The knocking is your parts salesman at your door. He is persistant and you might as well take it apart.
Take it slowly. Don't make a rash decision to tear it down yet. Check the cam and crank and see if both are at TDC at the same time. If they are, you're probably not too bad.
How about pulling the coil wire from the dizzy and taking out the plugs, then turning the engine over with the starter? Watch and see how quick your oil pressure light goes out and listen for strange noises.
Then start it for real and listen. Run in up to 3000 and listen.
I feel your pain. Last summer I decided to replace all of the hoses and water pump on my e46. The little metal clips that BMW uses to hold the hoses on the E46 are total shit. They look like they're engaged in their little slots, and it felt tight, but my lower radiator hose backed off of the radiator on the Interstate at 70 mph after 3 days of driving. The temp gage went to full hot before I saw it and shut it down (who stares at their temp gage driving down the highway?).
It wouldn't restart when it cooled off (with new water) I love the car, and it was nearly paid off, so I bought the bullet and replaced the engine. I probably should have parted it out and bought an E30 or 02, but I SPENT $8,000 INSTEAD. So don't feel too bad. The M10 is like a tank; the M52 is like a house of cards.
John in the Columbia River Gorge
1976 2002 Chamonix/Navy - SOLD
2001 330i
iirc the old spring was reused, but new chain guides were installed. with the head pulled, im having a very difficult time finding damage on pistons and valves. leaving me to also suspect the chain may have jumped.
can the lower timing chain cover be removed without draining the oil?
head is pulled. found a small divet in #1 piston. #1 and #2 exhaust valves have small pieces missing from the edge of the valve face ( away from where the valve seats). timing chain didnt move but i marked it and will double check when i reinstall. new head gasket, check compression and pray i didnt blow piston rings.
