what kind of alternator?
Dirka
I have H4s and i need an alternator with more amps because my h4s dim when gas pedal is released as well as dash lights... How big should i go?
Can an 85amp solve this problem??
Thanks
Damian
76 2002
Dirka Dirka..
it's not the " H4s" it's the WATTAGE BULBS you
have stuck in the H4 light units ?
condition of the battery?
condition of wiring at the alternator?
condition of all ground connections?
charging output of the alternator/voltage regulator?
'stock' alternator will not do that
MIN - you should invest in a VOLT/OHM meter
to measure the voltage at the battery key off,
during cranking, during 3,000 rpm charging.
voltage reading at the head light wiring sockets
while at 3,000 rpm and idle
with batery and charging system healthy,
there souuld be no dimming at idle.
Yes - maybe some-
at idle with HEATER FAN running, RADIO on, LIGHTS on,
and BRAKE lights on. But with 55W bulbs - should be no 'issues'
with stock charging system. This all assumes you have a strong
55 / 66 AMP HOUR battery
'64 R27 250cc #383851 18,000m
