Shifter shifts too much
ed3590
Sorry for the stupid question. I've read many posts on this subject but I'm still having problems. My shifter moves quite a lot. Under the car I can move the metal "brace" that seems to locate the shifter. The shifter moves up and down and side to side. The bolt/nut here:
>This may seem obvious, but I can
see #11? you need 2 of them:
http://www.bmwmobiletradition-online.com/bmw/showparts.do?model=2583&mospid=47141&btnr=23_0774&hg=23&fg=15
you might want to change #19, also.
and you will probably need 2 of #19 here, too:
http://www.bmwmobiletradition-online.com/bmw/showparts.do?model=2583&mospid=47141&btnr=23_0775&hg=23&fg=15
and i hope you removed that metal band around the guibo
Ken Inn
..and there should be a special oil & heat resistant
insulation pad around the shifter socket which you compress
up against the tunnel when you loosen the angle support
arm - press the shift platform up against the pad/tunnel,
then tighten the angle support arm. Yes there is a small rubber
bushing on the lower end of the angle arm
and to repeat - - - REMOVE THE METAL BAND from the rubber guibo
before driving
'64 R27 250cc #383851 18,000m
Thanks for the input.
I found that picture in another forum and it was much better than any picture I could take myself. I do not have a metal band around the guibo.
I now assume I must remove the exhaust and drive shaft, true?
You might be able to get to the shifter mount parts with the driveshaft and exhaust in place, but I would remove them for complete access. If the shifter mounts are that bad, then most likely all your shifter-related parts are toast.
While you are in there, inspect the reverse light switch, rear tranny mount and trans output shaft seal.
