Are these the correct rocker panel clips?
Upgrading my aluminum rocker panels and in my search to locate replacement clips i noticed that the clips that were on my car are quite different from the replacement ones i've been finding.
I've uploaded two photos. One has the broken clips removed from my car, the other the new replacement clips.
Did the previous owner have the wrong clips on my car?
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2000 Porsche Boxster
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
Top clips are the correct ones. What do you mean upgrade? Im in need of the drivers side rocker panel. Do you got one?
Mine are functional but old and beat up. Found new ones for $50 each and am going to get them. If you are in Los Angeles you can have mine. Just have to pick it up.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
Here is a price comp, I just bought some from BLUNT, $30 for all the rocker trim fasteners.
Lower Trim Fastner kit.
14 plastic clips  1.09
2 t bolts 6.88
2 nuts .89
Careful now. The center clip in this pic is not correct and will not hold securely.
GL,
Ray
Ray
The number i have for the clips is: 51 13 1 829 904
I think I'll try to polish my rocker panels using Bar Keeper's Friend instead of spending the $100 for new ones.
The synthetic weatherstripping is so expensive. Will try to keep my old ones. Missing just the short pieces at the front of car on both sides.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
Still, be sure the clips clip tenaciously.
GL,
Ray
Ray
#19 is what you need:
http://www.bmwmobiletradition-online.com/bmw/showparts.do?model=2583&mospid=47141&btnr=51_3379&hg=51&fg=20
HOWEVER, they are a tad small. we have complained to bmw forever. make sure you have t bolts in really good condition, and if you can reuse the old clips, at least a few, that helps. but them suckers are loose
Hey Ken have you seen the clips i removed before? They actually were a very snug fit. I didn't realise the proper clips were not great and unfortunately removed all the old ones.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
yes, i have seen them. all i can say is that wherever you do get the clips from, there is only 1 supplier. dont shoot the messenger
Do you know what the order number for them is? I've ordered the correct clips but if the fit is loose and flimsy i'll order the old clips i referenced from you guys.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
the problem is you cannot get the old clips any more. what happens is bmw quits producing them, the original vendor throws away the tools and molds. then, when mobile traditions was established, bmw started reproducing some of the long since nla parts. so they have to get new vendors, make new tools, yada, yada. and some of the attention to detail is just not there. one of our jobs here is to send feedback to mobile traditions. since i have been reprimanded before about what i post(if yale rachlin was still alive, and saw this, he would be cracking up), i will leave it there.
Ken Inn
Oh no, so i had some cool old vintage clips that worked great, that i yanked assuming the newer or "correct ones" would be better. Hilarious.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
Hit up your local (or not so local) suppliers and see if they have any old stock. I found almost enough that way!
GL,
Ray
Ray
