1972 2002: Now with Megasquirt/ITB Goodness.
The Westco battery that has lived under my back seat for 7 years finally gave its last. I know there are lighter options, but 7 years is a nice run for a battery. I decided to buy another one just like it.
-David
1972 2002 - 2577652 Follow the fun
  • 5 months later...
This stupid $0.05 fuse provided much stress yesterday. It popped while plugging in my phone charger to my 12V socket. Unfortunately that fuse also runs the auxiliary gauges including my AFR gauge. This also cut the signal from the 02 sensor to the ECU.
Thankfully I thought to toss a spare into my tool kit. The drive home was much less stressful. Will diagnose the reasons for the fuse popping later.
-David
  • 1 year later...
So, today, I switched from an external fuel pump to the in tank set up. I thought I was seeing signs of fuel pump failure, so I figured now was the time. I will probably change up the fuel filter set up, but it works well for now.
Forgive the filthy car! That’s what trunk floor panels are for. LOL
-David
  • 5 months later...
My car was purchased new here by a Dr. Norman Roberts of Seattle. I have been searching for one of these for a long time. A friend of mine sent me a link to an eBay auction with a buy it now button. Seller said it was on an E21 in a junkyard in Minnesota.
-David
Fuel Filter did you say?
 $39.00 Amazon:
Slightly more expensive from Radium with check valve and heat diffuser:
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
  • 5 months later...
So, I ended up cleaning up some of the plumbing in and around the gas tank. Instead of the old Hengst filter seen in the photo above, I bought a filter at Summit Racing. I added some fittings, Adel clamps and things are a little cleaner.
-David
