savvy
HELP! Brake Master Cylinder
5 posts in this topic Last Reply
I went to my local dealer (Weatherford BMW) to order a master cylinder rebuild kit......
I was told my brake master cylinder never existed on a BMW, let alone my Oct. '65 1600.
I showed him the photo, Fig 10:19 pg 104 of BMW 1600 1966-70 Autobook.
He looked in all his very worn parts books. He showed me a ton of pictures of BMW BMCs, none were the same as what I have.
He said that according to all his resources, the BMC for my car has a stop switch mounted at a 45 degree off the bottom.
There is one cylinder that is said to fit my car matching that description in Germany for $400.
Of course, special orders are not returnable.
RealOEM does not list the BMC that I have either.
Attached are photos.
It has 3 brake line connections, all at the front end of the cylinder: one at the forward top (12 o'clock), one at about two o'clock, and one at six o'clock (this port has 2 brass extensions attached).
The reservoir feed attaches at the top of the back third using a rubber grommet (press fit).
There are a pair of numbers cast into the cylinder body on the fender side; number 11 is toward the front and number 17 is toward the rear.
There is a blue tag attached at the rear that reads,
"Ate AnschuB mit Spezial-Bodenventill".
The stop light switch is mounted on the front, in parallel with the cylinder.
I'm looking for BMC part number and rebuild kit part number.
And.....if anyone knows availability.
Thanks!
Nick,
Thanks for sharing.
I hope to have my "under-the-hood" that clean soon.
Cheers!
Thanks Karl.
I'm going to go with Carl Nelson in San Diego.....
Hopefully it's rebuildable and not too coroded.
Cheers!
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
