Sign in to follow this
im3crazy
WIRING COLOR CODES AND DIN STANDARDS
3 posts / 21264 viewsLast Reply
This might make a good FAQ article since there are continuous questions regarding the various wiring diagrams and color codes. We could also provide a library of the wiring diagrams that have been collected on the forum.
DIN WIRING AND TERMINAL STANDARDS
Provided by im3crazy 3-16-2011
From Bosch Automotive Handbook, 3rd edition
We all have seen the number codes on our relay and other electrical terminals, but many
of us probably don't realize that these follow the DIN standard. Once you understand the standard it's much easier to troubleshoot the many grmelins that live in the '02s.
I've also included the color codes and gauge size crossover to AWG sizes.
It also might be helpful in future to include a common wiring scheme for the 02 models e.g. ground=brown, accessory/radio connection=violet/white; horn switch lead =brown/yellow etc.
Terminal Designations (Excerpts from DIN Standard 72 552)
The terminal designations do not identify the conductors, because a device with different terminal designations can be connected at the opposite ends of each conductor. If the number of terminal designations is not sufficient (multiple-contact connections), the terminals are consecutively labeled using numbers or letters whose representations of specific functions are not standardized.
WIRE COLORS
English .......................DIN (German)
Black . . . . . . . . . . . . . . . . . . . . .Sw
Blue . . . . . . . . . . . . . . . . . . . . . .Bl
Brown . . . . . . . . . . . . . . . . . . . ....Br
Green . . . . . . . . . . . . . . . . . . . . ..Gn
Gray . . . . . . . . . . . . . . . . . . . . . .Gr
Orange . . . . . . . . . . . . . . . . . . .....Or
Pink . . . . . . . . . . . . . . . . . . . . . .Rs
Purple . . . . . . . . . . . . . . . . . . . ...Vi
Red . . . . . . . . . . . . . . . . . . . . . ..Rt
Turquoise . . . . . . . . . . . . . . . . . ....Tk
White . . . . . . . . . . . . . . . . . . . . ..Ws
Yellow . . . . . . . . . . . . . . . . . . . ..Ge
Wiring Sizes: Metric - AWG
.5mm = 20AWG
.75mm = 18AWG
1.0mm = 16AWG
1.5mm = 14AWG
2.5mm = 12AWG
4mm = 10AWG
Ignition
1 . . . . . . . . . . .Ignition Coil, Distributor Low-Tension Circuit
Ignition Distributor With Two Insulated Circuits
1a . . . . . . . . . .to Ignition Point Set I
1b . . . . . . . . . .to Ignition Point Set II
4 . . . . . . . . . . . High-Tension Circuit
4a . . . . . . . . . .Terminal 4, from Coil I
4b . . . . . . . . . .Terminal 4, from Coil II
15 . . . . . . . . . .Switch-Controlled Positive Downstream from Battery
(from Ignition Switch)
15a . . . . . . . . .In-Line Resistor Terminal Leading to Coil & Starter
Glow-Plug Switch
17 . . . . . . . . . .Start
19 . . . . . . . . . .Preglow
30 . . . . . . . . . .Line from Battery Positive Terminal (Direct)
31 . . . . . . . . . .Return Line from Battery Negative Terminal
or Ground (Direct)
31b . . . . . . . . .Return Line to Battery Negative Terminal or Ground Via
Switch or Relay (Switch-Controlled Ground)
Electric Motors
32 . . . . . . . . . .Return Line*
33 . . . . . . . . . .Main Connection*
33a . . . . . . . . .Self-Parking Switch-Off
33b . . . . . . . . .Shunt Field
33f . . . . . . . . .for Reduced-RPM Operation, Speed 2
33g . . . . . . . . .for Reduced-RPM Operation, Speed 3
33h . . . . . . . . .for Reduced-RPM Operation, Speed 4
33L . . . . . . . . .Rotation to Left (Counterclockwise)
33R . . . . . . . . .Rotation to Right (Clockwise)
*Polarity Reversal of 32/32 Possible
Starter
45 . . . . . . . . . .Separate Starter Relay, Output: Starter;
Input: Primary Current
Flasher Relay (Pulse Generator)
51 . . . . . . . . . .Input
49a . . . . . . . . .Output
49b . . . . . . . . .Output to Second Flasher Relay
49c . . . . . . . . .Output to Third Flasher Relay
Battery Switching Relay
50a . . . . . . . . .Output for Starter Control
Start-Locking Relay
50e . . . . . . . . .Input
50f . . . . . . . . .Output
Start-Repeating Relay
50g . . . . . . . . .Input
50h . . . . . . . . .Output
AC Generator (Alternator)
51 . . . . . . . . . .DC Voltage at Rectifier
51e . . . . . . . . .DC Voltage at Rectifier with Choke Coil
for Daylight Operation
Starter
52 . . . . . . . . . .Starter Control (Direct)
53 . . . . . . . . . .Wiper Motor, Input (+)
53a . . . . . . . . .Wiper (+), End Position
53b . . . . . . . . .Wiper (Shunt Winding)
53c . . . . . . . . .Electric Windshield Washer Pump
53e . . . . . . . . .Wiper (Brake Winding)
53i . . . . . . . . .Wiper Motor with Permanent Magnet & Third Brush (for Higher Speed)
55 . . . . . . . . . .Front Fog Lamp
56 . . . . . . . . . .Headlights
56a . . . . . . . . .High Beam with Indicator Lamp
56b . . . . . . . . .Low Beam
56d . . . . . . . . .Headlight Flasher Contact
57 . . . . . . . . . .Parking Lamps (in some export markets)
57a . . . . . . . . .Parking Lamps
57L . . . . . . . . .Parking Lamps, Left
57R . . . . . . . . .Parking Lamps, Right
58 . . . . . . . . . .Side-Marker Lamps, Taillamps, License Plate
& Instrument Illumination
58d . . . . . . . . .Rheostatic Instrument Illumination, Tail- & Side-Marker Lamps
58L . . . . . . . . .Left
58R . . . . . . . . .Right, License Plate Lamps
(Magneto Generator)
59 . . . . . . . . . .AC Voltage Output, Rectifier Input
59a . . . . . . . . .Charging-Armature Output
59b . . . . . . . . .Taillamp Armature, Output
59c . . . . . . . . .Stop-Lamp Armature, Output
61 . . . . . . . . . .Charge Indicator Lamp
Tone-Sequence Controller
71 . . . . . . . . . .Input
71a . . . . . . . . .Output to Horns I & II (Bass)
71b . . . . . . . . .Output to Horns 1 & 2 (Treble)
75 . . . . . . . . . .Radio, Cigarette Lighter
76 . . . . . . . . . .Speakers
77 . . . . . . . . . .Door Valve Control
Switches, Normally Closed (NC) Contacts & Changeover Contacts
81 . . . . . . . . . .Input
81a . . . . . . . . .First Output on NC-Contact Side
81b . . . . . . . . .Second Output on NC-Contact Side (NO Contacts)
82 . . . . . . . . . .Input
82a . . . . . . . . .First Output
82b . . . . . . . . .Second Output
82z . . . . . . . . .First Input
82y . . . . . . . . .Second Input
Multiple-Position Switch
83 . . . . . . . . . .Input
83a . . . . . . . . .Output (Pos. 1)
83b . . . . . . . . .Output (Pos. 2)
83L . . . . . . . . .Output (Left)
83R . . . . . . . . .Output (Right)
Current Relay
84 . . . . . . . . . .Input: Actuator & Relay Contacts
84a . . . . . . . . .Output: Actuators
84b . . . . . . . . .Output: Relay Contacts
Switching Relay
85 . . . . . . . . . .Output: Actuator (Negative Winding End or Ground)
Input: Actuator
86 . . . . . . . . . .Start of Winding
86a . . . . . . . . .Start of Winding or First Winding Coil
86b . . . . . . . . .Winding Tap or Second Winding Coil
Normally Closed (NC) Relay Contact & Changeover Contacts
87 . . . . . . . . . .Input
87a . . . . . . . . .First Output (NC-Contact Side)
87b . . . . . . . . .Second Output
87c . . . . . . . . .Third Output
87z . . . . . . . . .First Input
87y . . . . . . . . .Second Input
87x . . . . . . . . .Third Input
Normally Open (NO) Relay Contact
88 . . . . . . . . . .Input
88z . . . . . . . . .First Input
88y . . . . . . . . .Second Input
88x . . . . . . . . .Third Input
Normally Open (NO) Relay Contact & Changeover Contacts (NO Side)
88a . . . . . . . . .First Output
88b . . . . . . . . .Second Output
88c . . . . . . . . .Third Output
Generator/Alternator & Voltage Regulator
B + . . . . . . . . .Battery Positive Terminal
B - . . . . . . . . .Battery Negative Terminal
D + . . . . . . . . .Generator Positive Terminal
C - . . . . . . . . .Generator Negative Terminal
DF . . . . . . . . . .Generator Field Winding
DF1 . . . . . . . . .Generator Field Winding 1
DF2 . . . . . . . . .Generator Field Winding 2
Alternator
J........Excitation winding positive
K........Excitation winding negative
Mp.......Center point terminal
U, V, W . . . . . .Three-Phase Terminals
Turn Signals (Turn-Signal Flasher)
C . . . . . . . . . . .Indicator Lamp 1
C0 . . . . . . . . . .Main Terminal Connection for Indicator Lamp Not
Connected to Turn-Signal Flasher
C2 . . . . . . . . . .Indicator Lamp 2
L . . . . . . . . . . .Left-Side Turn Signals
R . . . . . . . . . . .Right-Side Turn Signals
Additional Wiring Color Coding
(earlier and later models)
Memory (+12v Constant)
Gray/Red
Ignition (+12v Switched) Violet
Ground (-) Brown
Illumination White/Blue
Dimmer (none)
Power Antenna White
S p e a k e r s
Right Front (+) Gray/White
Right Front (-) Gray/Brown
Left Front (+) Gray/Red
Left Front (-) Gray/Violet
Right Rear (+) Black/White
Right Rear (-) Black/Brown
Left Rear (+) Black/Red
Left Rear (-) Black/Violet
MORE DETAILS TO BE ADDED E.G BMW 2002 wiring color coding; various wiring diagrams; wire harness layout and sizing etc.
END
Thanks for this post dude. This is really helpful. I'm having some difficulty trying to figure which wire is for what. With these code and markers I can easily identify them.
Admins: This post might be best included with the Ireland Engineering post showing the color coded wire diagram.
The standard DIN numbering codes (e.g. 31, 31b, 51 etc) in this first article explains the function of each wire or device connection.  Used in combination, they help unravel the mystery of BMW (DIN) color assignment by function.
We still print out the large (18x24) wall-mounted wiring diagrams updated with a side-bar list of these DIN color codes.  Really helps figuring out the daemon electrical faults!
Dave Bickel
