SoCal Vintage is Here!
Post your photos!
Hose ?
What is the hose that goes from the intake manifold to the brake booster? The plastic piece on my brake booster is broke so the hose just hangs there.
specific type of hose that's wire reinforced so it won't collapse under vacuum. You can get it by the meter from Blunt (Steve Peterson) on the FAQ. There's a long piece, a one-way valve, and a short piece that connects the valve to the manifold. Suggest ordering the short piece for a 320i vs the 2002 part; the 320 part is moulded with a right angle and won't have the tendency to crack like the straight piece used on a 2002.
Also make sure you test the one way valve and install it correctly!
cheers
