Lever Return Spring
cxzsaq
Sorry - you are looking for the spring not the lever.
Plugged your P/N into Max's site and:
09 TENSION SPRING 1 13541256709 N/A ENDED
It is NLA (No Longer Available) new. I'm sure someone here can sell you a good used one (Rob Torres, Sherman Martinez, etc.)
For the aluminum runner version -
06 TENSION SPRING 1 13541257052 $4.19
  • 4 months later...
Also looking for this part no. which is NLA.
Does anyone have a used one?
If not, any ideas on tension, length, etc. for making one?
Lastly, what does this spring do?
The spring holds the butterfly on the throttle body closed at idle. It works together with the spring at the firewall pivot and at the pedal box.
  • 8 years later...
On 5/18/2020 at 10:45 PM, Half Moon tii said:
I had planned to purchase a new spring, but now cannot find easily.  Does my spring look stretched?  I had it coated with other parts, but I believe it to be original.
Yours looks to be stretch. Im not in front of mine but should be compacted on both sides. Yours is compact on left but loose on the right. I suppose if it works, let it be.
