Tachometer trouble! HELP
aerowise
Tach stopped working! Pulled guage cluster and alls well there, no disconnections. Checked wire to dist. and that's good too. Can't seem to figure it out. The light on the tach is dimmer too.
Can I buy a universal tachometer to test this? Thanks!
REPLY: check contenuity of signal wire from coil wire to tach with ohm meter??
If there is no signal to the tach then what is the next step to fix this? HELP!
