flex disk
alternate the head of the bolts
leave the installation metal band around the joint untill finished
eith tightening all nuts
if done and aligned properly, the joint will rotate
without any 'wobble' , but instead spin wih no stress
causing deflection what so ever.
clean out, and refill the end of the drive shaft
with high temp wheel bearing grease (moly prefered)
so the end of the drive shaft floats freely
in the trans output shft end
