tii air filters
You can always remove the entire canister (4 bolts on the inner fender) to remove the back side if its too tight.
Matthew Cervi
'73 tii
Sometimes they are tight and hard to release. It may take some rearranging, but the rear cover CAN come off without pulling the whole air cleaner assy. If you are apt to be impatient, it might be better to just pull the whole air cleaner out. Just remember the brake vacuum line is in a clip underneath, and the small evap line at the top.
