yeee!! wiring geeks only!!!
URL: http://www.bmw2002faq.com/02s_online/links.html
Ive got my starter, ignition, and fuel pump circuits wired (switched) seperately now so i can turn the motor over until i get oil pressure, then add spark/fuel (seperately, if needed) to fire the motor. also i am eliminating the seperate driving lights and fog lights switches in favor of simply tying them to the high and low-beam circuits, respectively. of course, they will still be cancellable by the old switches, but in ordinary driving I'll only need to operate the highbeam switch to fire the 100w driving lights as well (foglights will be on whenever lows are running). ahh, the wires..... ;p
-Rob
'02 FAQ Editor
waytekwire.com. Lots of auto related, bosch relays, etc, theres a bosch relay that can be substituted for the factory one, if you just switch around a couple of wires, SPST, other interesting items, cut-off switches - keyed, wire loom,
until pressure builds, and yes, i am a wiring geek. there are the anti-theft aspects also of having an incomprehensible starting sequence.. ;p
-Rob
