02again Pulley Question
jmp88
Does anyone else have the EDIS crank pulley from Tom Rafalski? I was just trying to install one and found that the 30mm socket I have is too big to fit inside the pulley so I can't tighten it up.
Does anyone have experience with this or a similar situation? I don't know if there's a smaller socket or whatever that I can get, this one seems pretty standard.
I think if you look at the Sears craftsman socket (part #44244) socket, you'll find it works jusf fine. the dimension inside is Exactly the same as the tii. Thanks
Thanks Tom, I got your email shortly after I posted this. I found the right socket online and I'm gonna head over to Sears tomorrow to pick one up. Thanks again for the parts!
