Help with Carb! Fuel Inj possibilities???(LONG)
idel problem. The solenoid must have 12 volts when the engine's running, or the solenoid will close off the idle jet (prevents dieseling). No idle jet, no idle...there should be a + 12v wire nearby that's live with the ignition on or you can always run a jumper wire from the 12v+ low tension terminal on the coil.
Cheers
Mike
