Guest Anonymous Posted April 20, 2003 Share Posted April 20, 2003 Hi all ive got a wber 32/36 that i rebuilt and i put it on the car and it was great for a while until the car started dieing at stops I have fiddled with the float level under my grandpas reccomendations to no avail. Any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 20, 2003 Share Posted April 20, 2003 the carburetor and mine had shorted out which didnt allow the car to idle< I had to constantly hold the gas. Hope this helps Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 20, 2003 Share Posted April 20, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 20, 2003 Share Posted April 20, 2003 URL: http://www.zeebuck.com/02bc/index.htm It cuts off the idle circuit of the carb if not supplied with power - it should have +12V power to it whenever the key is in start or fahrt. Definitely a place to look, if you have one. Otherwise, may be just a clogged idle jet or maybe loose throttle linkage bits allowing the throttle to close completely - I have seen it happen. regards, Zenon Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 20, 2003 Share Posted April 20, 2003 have you checked the brake booster and vacuum hose for leaks? maybe! bob Quote Link to comment Share on other sites More sharing options...
