Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 I found a decent set of e30 seats at the yard today, I saw in the FAQ that a few people have installed them, but i am just wondering how much work is involved in that process? and how high do they sit? would a 6'2" person like myself have any head clearence issues? I also stumbled across a 2800 with two new carbs, they were webbers, but i didn't know how to tell what type? is there an easy way to ID 38's/45's etc? thanks! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 got to http://www.ramflo.netfirms.com/ and to got Weber Carburetors. You will see the images of all the carbs. if they are sidedrafts there will be a marking on them indecating weather they are 40s, 45, 48s and so on. steve k. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 They look very simular to the stock carb in my 2002, the port openings are a bit larger, and both ports are the same size.. can i just measure em? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 yah, you can measure them. but you will need to remove the vinturis and measure the actual bore, but there should be some numbers posted on the top of the carb. steve Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Share Posted April 18, 2003 the 38/38 has a gear on the back so that both primary and secondary open together. Shoot me a note if this is the case Quote Link to comment Share on other sites More sharing options...
