SoCal Vintage is Here!
Post your photos!
Help in Houston...
Codfish
I am at the point of fixing this car with a baseball bat...
At first when I attempted to start the car it sparked at the throttle connection on the firewall (no spark to the engine). I checked all the wires and found nothing wrong according to the diagrams that have been posted here... Now when I attempt to start the car all I hear is the click from the starter.
-I get 12 volts at the coil with the car in the on position
-The car no longer turns over it just clicks (battery is good)
-I have been trying to trace this issue for the last month
Here is the build out...
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,325122/highlight,sabrina/
HELP PLEASE !!!
Ill buy the beer and BBQ (thats how we do it here in Texas)
Peace and Thanx
Wayne
usually that's a sign of a weak battery or bad starter. Try jumping the car off another, running car. If you just get the click, sock the starter with something like a hammer handle, and check the wires to it and the grounds. If that doesn't work, take it to a parts place or shop where they can check it.
Thank you Gentlemen... I moved the ground strap and now it cranks like it should.
The second issue I am having is the lack of spark... I am using the diagram below (its for the 6 fuse setup). The second green wire off the relay doesn't state where it goes.
Is it to the ignition?
I am also not sure if the crane xr-700 is working is there a way to test it ?
Thanx in advance
Wayne
Wow Wayne - glad to see you are making progress.
That looks like an older Crane unit. The newer ones have a red light on the top that blinks when the unit is firing.
Not sure on the wiring. I just went and looked at my car, and yours being an earlier 2002, they are wired differently.
Sorry.
Ken
Thanks Ken, this no spark issue is driving me nuts... But I am much happier now that I got rid of arc (due to a bad ground) problem... Once again THANKS guys !!!
Anyone know of a way to test the Crane xr-700 ???
